Author: Subject: Which angle grinder?
cliftyhanger
posted on 16/6/12 at 04:11 PM Reply With Quote
After using a mates bosch angry grinder today I have seen thye error of my ways and feel I ought to uy a quality bit of kit.
However, which is the best one, must be 4 1/2" and decent. There seem to be the bosch gws 660/850 etc and also 8-115 and so on, but which is the better?? Or another brand/model. Ideally about £50 give or take.
Clive
posted on 16/6/12 at 04:38 PM Reply With Quote
Bosch, Metabo or Makita are good makes. Some people will swear by De Walt or whatever they use and it's one of those cases where you pays your money and takes your chance. I recently bought a Metabo WE14-125 Quick from ebay (outside your budget) and it's a brute. It has variable speed and a quick nut for disc changes plus you can't switch it on accidentally as it has a safety feature to stop it working if switched on at the socket with the trigger engaged and a clutch for if the disc jams. I splashed out as I burnt out 3 of my cheap ones in 2 weeks although they had seen lots of work.
Metabo have a 3 year warranty if you register you purchase but I've not had to use it.
[Edited on 16/6/12 by Peteff]
tomgregory2000
posted on 16/6/12 at 04:46 PM Reply With Quote
Get yourself the BLUE bosch angle grinder in 240v (also comes in 110v) not the green one!!!This one
[Edited on 16/6/12 by tomgregory2000]
BigFaceDave
posted on 16/6/12 at 06:28 PM Reply With Quote
I got a green bosch one from Makro a couple of years ago and its been very good and was only about £29 I think but we have the blue ones at work and they get thoroughly abused 6 days a week and last about 6 - 8 years!
degmwilliams
posted on 16/6/12 at 06:56 PM Reply With Quote
Bosch are very good, Gws 660/850 is the watts, the higher number the more power the motor has, 8 115 means its 800 watts and 115mm which relates to 4.5". You can't expect to go to b&q and buy a £35.00 Bosch and it be the best grinder ever when it's only a 550 watt, you need to get a industrial 850 watt Bosch if you want a proper grinder that's gonna last.
[Edited on 16-6-2012 by degmwilliams]
Building a tiger Avon st170 (slowly)
ashg
posted on 16/6/12 at 06:57 PM Reply With Quote
i have gone through about 4-5 angle grinders bosch, dewalt, power devil, b&d. none of them lasted. i then thought what the hell and splashed out £50 on a 115mm makita, never looked back its four years old now has built two cars, fixed many others and also did all the chopping out of the walls when rewiring mine and my brothers house. it doesn't matter what stupid things i do to it i just cant kill it, and it doesnt matter how hard you use you will never manage to stall it.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
HowardB
posted on 16/6/12 at 07:18 PM Reply With Quote
had a bosch blue, and a makita, both excellent, and both will work all day without complaint,...
Howard
cliftyhanger
posted on 16/6/12 at 07:37 PM Reply With Quote
hmm which one:
http://www.toolstation.com/shop/Power%20Tools/Grinders/Makita%209554NBKD%20115mm%20Angle%20Grinder%20/d40/sd3149/p66579
http://www.toolstation.com/shop/Power%20Tools/Grinders/Bosch%20GWS%20850%20Professional%20Mini%20Grinder/d40/sd3149/p19115
http://www.screwfix.com/p/bosch-gws-660-4-angle-grinder-240v/77886
or any other specific suggestions???
The wife has OK'd it too. Must be my lucky day
posted on 16/6/12 at 09:36 PM Reply With Quote
The only thing I'd say is- make sure as much as it as possible is metal. I had an angry grinder die when the bearing carrier that sits under the disc (made from best engineering plastic (IE plastic)) melted due to some serious grinding. The disc got some serious wobble as the bearing moved in the molten plastic and vibrated itself out of my hand. Luckily I was quick with the off switch and managed to drop it without it taking a chunk out of me. So now I only use grinders with metal bearing carriers.
posted on 16/6/12 at 10:07 PM Reply With Quote
W680 Metabo 705 Watts 115mm 4 1/2' Angle Grinder 240v 4007430202291 | eBay probably.
matt_gsxr
posted on 16/6/12 at 10:13 PM Reply With Quote
Originally posted by cliftyhanger
hmm which one:
I got that Makita one and it is brilliant.
cliftyhanger
posted on 17/6/12 at 09:45 AM Reply With Quote
just bought the makita one. A "posh" anniversary versuin in trendy white, on special offer at axminster tools.
So in a couple of days all will be good in my world
Thanks for all the pointers
Clive
