Author: Subject: MT75 gear lever pin problem
i_froloshki
posted on 5/7/12 at 12:54 PM Reply With Quote
Hello all,
i have problem with the pin under position 5. It is very loose and if falls from the engine/gearbox vibration. Can i put a bolt there and secure it with nut or should i look for another solution? Any ideas? I think there should be some gaitor there - does it cover and hold it?
pin problem
pin problem
Thanks in advance
Yavor
[Edited on 5/7/12 by i_froloshki]
Chaz
posted on 5/7/12 at 02:32 PM Reply With Quote
Hi there, interesting you say this as I had the same problem but only remember now you mention it. I think I just tie wrapped it!!! I have done 1500 miles in it so no probs. if you find a better solution let me know.
Are you mounting it to a zetec?
big_wasa
posted on 5/7/12 at 03:38 PM Reply With Quote
There is a wire clip that goes around it. You can see there is a groove that it sits in. Will see if I can find a photo.
hootsno1
posted on 5/7/12 at 05:03 PM Reply With Quote
GBS do a replacement part much easier to change than the standard ford one
If a little hammer won't fix it get a bigger hammer
zetec-phill
posted on 8/7/12 at 12:11 PM Reply With Quote
if its the pin that goes through the gear selection rod..?
i bought a new lever a carriage for mine fron ford, a it came with a bolt a locknut
