Author: Subject: drums or discs?
Slimy38
posted on 10/7/12 at 07:30 AM Reply With Quote
drums or discs?
Standard Tiger Avon build, with a 2 litre Pinto on carbs. Car is intended for the road with very little trackday action. Would drums on the back be adequate, or should they be replaced by discs? If drums are ok for now, at what point would you change to discs, assuming there is a point that you'd swap to discs?
ReMan
posted on 10/7/12 at 07:44 AM Reply With Quote
Personal choice. Drums adequate even on track.
It's more about looks. ISTR Drums are lighter though.......
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
matt_gsxr
posted on 10/7/12 at 08:03 AM Reply With Quote
Agreed with above.
Disks look better but in practice are probably inferior (handbrake is way better with drums).
ditchlewis
posted on 10/7/12 at 08:29 AM Reply With Quote
Another vote for drums. Have a tuned pinto and have never had problems stopping.
Ditch
ditchlewis
posted on 10/7/12 at 08:35 AM Reply With Quote
Ditch
stevegough
posted on 10/7/12 at 09:19 AM Reply With Quote
Yep. Drums - crappy handbrake with rear discs. The fronts do most of the stopping, and you can always change the pad types to suit the type of driving. The cars are too light to warrant rear discs.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
designer
posted on 10/7/12 at 09:47 AM Reply With Quote
Drums
Slimy38
posted on 10/7/12 at 09:49 AM Reply With Quote
Thanks for the responses. It was my brother in law that inspired the question, I had just assumed that discs on back = good. But he mentioned that his Nissan Micra has rear discs, and the mother of all bias valves to stop the car spinning down the road. And even a Micra is a heavyweight compared to an Avon.
stevegough
posted on 10/7/12 at 10:06 AM Reply With Quote
You could do a 1st.... drums on the front and discs on the back.....would be different! (Or one of each on each axle - that would be an interesting drive on a wet road...)
Luego Locost C20XE.
