Author: Subject: Wanted - non bubble aeroscreen
Krash67
posted on 14/7/12 at 01:11 PM Reply With Quote
As the description says wanting a simple full scuttle width aeroscreen. Have tried various sources, but either to big (bubble versions) or not available on stock.
Colour black/ carbon effect.
U2U or email me iancrashley@aol.com
Ian
If your not fast..........your last!!!
pewe
posted on 14/7/12 at 01:37 PM Reply With Quote
Mac#1motorsport supplied mine linky.
It's shallow smoked perspex(?) with curved edges. Cost c.£40 but that was some time ago.
Fitted it by making up an ali angle plate across the centre about 200mm wide, riveted to the scuttle then bolted to the screen with rubber washers under the bolt heads.
Ends are supported on home-made angle brackets again rubber insulated.
Pics if you want them.
HTH.
Cheers, Pewe10
