Neadles
| posted on 21/7/12 at 10:56 AM |
919 Fireblade operating Temps
I've just got my first locost car a Fury and am new to bike engines so just wanted a little guidance, what is the normal operating temps?
I've had it sat on the drive to warm up and check the fan cuts in and it seems to sit at 95 with the fan on constantly, oil temp sits at 85-87
constantly. Then when you put sum revs on water temp gets to 100-104 and again won't recover but again oil temp is the same. Now I appreciate
bikes run hot but the radiator is larger however the upper water pipe is a very small diameter so is this normal or is the water temp sender reading
wrong??
Chris
fullpint
| posted on 21/7/12 at 12:06 PM |
Hi Chris,
My runs at 100 if sat in traffic but soon drops to about 85. My pipes are the same diameter all round.. Post a pic showing your small one, it may help
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
PAUL FISHER
| posted on 21/7/12 at 01:09 PM |
100 to 104 is too high for normal operating temperature, normal operating temp is between 80 and 90 for a blade, mine sits at 80 to 82, and goes to 85
when I give it some stick.
zekill
| posted on 21/7/12 at 03:55 PM |
- engine run too lean ?
- with Fury or Phoenix it's better to make an air ducting for radiator
- mine run at about 90°, correct jetting, air ducting and water + mocool
piping for blade is 1 inch, polo radiator is 1.25 inch, i use reductor elbow at radiator input/output.
hope that help.
Fisher Fury with Phoenix bodywork, Blade 919cc
Neadles
| posted on 21/7/12 at 06:45 PM |
Thanks for all your reply's people, just to update a little,
all the figures quoted were the car sat on the drive way, but some update from today's trip out! The water temp sat at 90 most of the time with
oil at around 80-85, but when in traffic sat water topped out at 105, though oil never went past 90. Now I'm still not convinced the water is
reading right. My tintops got to 110 water but oil never got past 100 so since I have not had oil past 93 then the temperatures are ok, but not sure,
what do everyone else's oil temps get too???
To answer a few questions:
There is ducting for the radiator to channel it all.
I have been told its been Jetted and dynoed so should be ok.
Radiator size and hosing sounds the same as everyone else's.
Will try check the water temp with another instrument, but as long as oil temp looks after itself and sub 100, I'm not too worried cos as far as
I am aware as long as oil does not past 130 it doesn't break down.
Though any more experiences or suggestions are welcome.
gixermark
| posted on 22/7/12 at 08:13 PM |
Depending on howling you were stuck in traffic that doesn't sound too bad.
If you have a proper header tank, a decent high pressure cap will help.. Make sure the water system is bled well.
You may be able to get a better 'race' spec fan, and flat out the sides to let the hot air out. If you put a manual switch on the fan, you
can turn it on yourself when you are coming into traffic, before it gets to 90+
Oil sounds good.
