Author: Subject: Tiger avon on a trailer
degmwilliams
posted on 22/7/12 at 08:44 AM Reply With Quote
Can someone please tell me the size of a finnished Avon. I'm buying a ifor Williams flatbed trailer and it might as well be one that a Avon fits on. Could do with knowing the width of the wheel centres and the length of the centres please.
Building a tiger Avon st170 (slowly)
AndyW
posted on 22/7/12 at 08:53 AM Reply With Quote
this is from the Tiger web site, hope it helps.
Model / type
Chassis Space frame 1inch box
Body GRP
Engine OHC Ford(pinto) Zetec
Other engines can be fitted.
Transmission Ford Sierra type 9
Steering Rack and pinion 3.7 turns(option quick)
Brakes Disc front, drum rear, option disc rear
Suspension Adjustable front and rear shocks
Front track 1300mm
Rear track 1485mm
Wheel base 2280mm
Overall length 3240mm
Weight 595kgs with Zetec
Wheels Standard Sierra offset
Tyres 185-60-14 (option 15inch
degmwilliams
posted on 22/7/12 at 09:02 AM Reply With Quote
Can that be right? The wheel base is nealy a meter less than the total length?
snakebelly
posted on 22/7/12 at 09:09 AM Reply With Quote
We have just bought a Brian James 14' flatbed for our gta which is based on the Avon and is fits fine if that helps
degmwilliams
posted on 22/7/12 at 09:25 AM Reply With Quote
Thanks for that but 14' is too big. I was hoping that the wheels would fit on a 10 x 5 or 10 x 6. I don't mind if it overhangs at the front or back.
AndyW
posted on 22/7/12 at 09:36 AM Reply With Quote
I just copied from their web site, so dont actually know. I assumed the manufacturer would do!!
renetom
posted on 22/7/12 at 09:49 AM Reply With Quote
trailer
Hi
We have an MK Indy which fits ok on our BJ Micomax trailer 10 ft X 5ft9inches
I think the Indy is a bit larger.
Trailer also fits in a std garage
See picts in our archive.
good luck.
degmwilliams
posted on 22/7/12 at 12:33 PM Reply With Quote
Thanks for that, pictures look good
