New Topic New Reply
Author: Subject: Floor pan, not frying pan!
jimmylad
posted on 24/7/12 at 03:24 PM Reply With Quote
Afternoon all,
I have got tot he stage were i am getting ready to fabricate the floor for my Locost,
My question is what would be best to use for the floor, Would 16 gauge aluminium or steel be best or was thinking of cutting the roof of the works transit van and using that as its a good (cheap) flat piece of metal.
What have other builder used?
Jimmy
big_wasa
posted on 24/7/12 at 03:28 PM Reply With Quote
I did mine in steel, pu'ed and rivetted to the chassis.
rodgling
posted on 24/7/12 at 03:29 PM Reply With Quote
Err... will your work not object to that?
jimmylad
posted on 24/7/12 at 03:31 PM Reply With Quote
They don't need to know haha. the van is a write off anyway
daviep
posted on 24/7/12 at 03:36 PM Reply With Quote
Are you sure the roof is actually flat?
I used 14swg aluminium.
Davie
whitestu
posted on 24/7/12 at 03:58 PM Reply With Quote
Steel is going to take a lot more effort to stop it rusting away if used in the wet / winter.
stevebubs
posted on 24/7/12 at 04:52 PM Reply With Quote
I think one of the recommendations in the original book was to use the Escort roof...
steel is heavier and will corrode, though - depends on you budget would be my answer...
spiderman
posted on 24/7/12 at 06:25 PM Reply With Quote
Steel also offers a greater penetration resistance than aluminium. Good for if you run over a silencer left behind by a truck or something similar, you really do not want an exhaust as an enema!
Spider
bi22le
posted on 24/7/12 at 06:34 PM Reply With Quote
I assumed all floors were ali. Steel would be a pig to prevent rusting.
Shows how little I know when I brought and not built!!!
Please read my ring story:
phelpsa
posted on 24/7/12 at 06:36 PM Reply With Quote
I have and would use 14swg ali.
degmwilliams
posted on 24/7/12 at 07:35 PM Reply With Quote
Iv got 1.2 mm Alu. 2500x1265 £48.00 from mill stainless
Building a tiger Avon st170 (slowly)
steve m
posted on 24/7/12 at 07:36 PM Reply With Quote
Mine is the roof of the donor escort, welded in,
works fine for me
flibble
0.9mm stainless, also pu'ed and riveted.
skodaman
posted on 24/7/12 at 08:41 PM Reply With Quote
Mine's zinc plated steel welded to chassis. Can't see rust being much of a problem compared to average tintop as it's a small flat area and easy to rustproof and keep an eye on. Also it's not likely to be going outside for a few years yet.
Skodaman
iank
posted on 24/7/12 at 08:56 PM Reply With Quote
If you want to run in the 750mc locost formula steel is required otherwise aluminium is more common these days.
Anonymous
coyoteboy
posted on 24/7/12 at 09:39 PM Reply With Quote
You must all be running your cars like gadget cars if you can get a truck silencer under them!
Chippy
posted on 24/7/12 at 10:08 PM Reply With Quote
Mine is steel, welded on. After 6 years there is not a trace of rust, so I suppose it all depends on your initial preperation. I etch primed then two coats of black ordinary house paint, then two coats of underseal on the bottom, still as good as the day I put it on. Cheers Ray
AdrianH
posted on 24/7/12 at 10:17 PM Reply With Quote
16 gauge steel zintec floor on mine puddle welded every two inches. Used zinc spray paint over the welds after and basically tried to run the paint between chassis and floor to seal any gaps, OK so far.
Has had big bash from underneath rear of drivers seat from when I moved a large stone or concrete rubble in road and it tried to come up through the bottom. of the car, looks like a large lump hammer job.
Adrian
Why do I have to make the tools to finish the job? More time then money.
wilkingj
posted on 25/7/12 at 08:10 AM Reply With Quote
My Luego Factory floor is steel.
Corrosion was my concern.
I gave it a good coating of paint and some stonechip as well. Also extra around the front edge of the footwells.
After 6 years, its still rust free.
I also painted all around the seams / joins on the inside of the floor with Grey Stripe Seam sealer. Namely to stop water creeping between th rails and the floor panel as its only stitch welded in.
Its not hard to stop the rust if you do it at the beginning whilst its easy to get at.
Dont leave it until its been on the road for a few years.
Best Regards
Geoff
http://www.v8viento.co.uk
New Topic New Reply
