Author: Subject: building/land surveyor wanted
matt.c
posted on 30/7/12 at 08:17 PM Reply With Quote
Can any any building/land surveyors help me with this problem?
HELP
Im getting desperate now.
designer
posted on 30/7/12 at 09:57 PM Reply With Quote
What about the survey you will be getting done?
matt.c
posted on 30/7/12 at 09:59 PM Reply With Quote
Yes. Just need advise on what will be in the survey and if its going to point out whats wrong and how to fix it.
zilspeed
posted on 30/7/12 at 10:05 PM Reply With Quote
Unless you specifically ask for an actual survey, you may actually be getting no more than a valuation.
You need to be very specific about this.
The clue is in the fee being charged.
matt.c
posted on 30/7/12 at 10:09 PM Reply With Quote
Ok im an idiot. What does this mean.
tegwin
posted on 30/7/12 at 10:13 PM Reply With Quote
A valuation type survey will be cheap (ish)..... A full land/geological/topo survey looking for underground streams/drainage etc will cost a LOT
[Edited on 30/7/12 by tegwin]
www.verticalhorizonsmedia.tv
matt.c
posted on 30/7/12 at 10:16 PM Reply With Quote
As the place is under 10 years old we went for the basic report (not the home buyers report).
I think the major report was over £1000
tegwin
posted on 30/7/12 at 10:19 PM Reply With Quote
That does not suprise me... and I suspect it would still not cover enough to help you with your squidgy lawn...
matt.c
posted on 30/7/12 at 10:22 PM Reply With Quote
Found this: look
Still even on the major inspection it doesn't seem to cover much on the outside of the house.
theconrodkid
posted on 31/7/12 at 06:24 AM Reply With Quote
i used to work for a co that did this sort of stuff.
water can be a killer on houses,you need to find the geoligy of the area and where the water mains run.
you could try water devining,it does work,that would give you a clue as to an underground stream.
personally,i would walk away
who cares who wins
pass the pork pies
