Author: Subject: 1800 gti silvertop zetec on gsxr itb's
marshal900l
posted on 1/8/12 at 05:20 PM Reply With Quote
hi everyone. right i have a escort 1.8gti silvertop zetec. i have just bought gsxr1100 throttle bodies which is on a st170 inlet manifold and has standard st170 injectors and also have a fuel pressure regulator to take my fuel pressure to 3 psi, and have a mtech v3 ecu which is the same as megasquirt v3. can anyone give me any sort of idea where i can get a map to put on my ecu?
zetec 1.8 base map or even a map ready set up for me to fit and go.
tried m tech and many other companies and not heard a thing back from them.
also if i have to change the injector cc/min or lbs/hr from the base map can anyone give me a idea of what digits i have to put in?
and i have read loads and and have a good idea of fitting but noone really explains how to set up the idle and fast idle as there is only a tps to go from and no idle valve?
hope someone can help me.
cheers
rob
