Author: Subject: Turbo Advice please (zetec)
six mad
posted on 2/9/12 at 06:09 PM Reply With Quote
Well I spent the most of the day between the GP, and lots of tea, fitting my turbo to
my zetec.
The car is running without the turbo outlet not connected to the inlet manifold, that plumbing and intercooler fitting will
be fitted another day.
Problem is the turbo is smoking its making boost (blowing air anyway) and sounds ok.
The turbo been rebuilt by the previous owner, bolts gaskets mounting plates all look new from the outside
so what could be wrong bad rebuild seals??
Oh was going to upload a pic, but how??
Thanks in advance
posted on 2/9/12 at 06:26 PM Reply With Quote
Do you have the oil drain plumbed in correctly (i.e. vertically downwards, and draining into the sump?
Are the engine breathers clear and routed correctly?
Do you have any required restrictors in the oil feed?
madteg
posted on 2/9/12 at 06:29 PM Reply With Quote
When is it smoking, on tick over, boost or overun also where about is the smoke coming from, exhaust or compressor side.
six mad
posted on 2/9/12 at 07:13 PM Reply With Quote
Yes all plumbed correctly- feed into the top return unto the block just near the flywheel sensor.
No restrictor though its feed from the oil pressure switch position???
six mad
posted on 2/9/12 at 07:15 PM Reply With Quote
Smoking at tick over and on throttle out of the exhaust not as much on overrun.
BigLee
posted on 2/9/12 at 07:43 PM Reply With Quote
Is it just oil residue on the turbo from its rebuild? Mine took about an hour to calm itself after fitting the 1st time.
What turbo is it? Some need restrictions to limit the pressure pushing past the seals. Have you tried any google searches based on the turbo rather than the specific install?
Lee
six mad
posted on 2/9/12 at 08:08 PM Reply With Quote
Lee
Thanks Lee it could be residue fingers crossed
The turbo is a series 2 RST unit but the compressor housing is labelled AIR RESEARCH???
I thought it may be a Hybrid of some type?
How do you limit the pressure?
madteg
posted on 2/9/12 at 08:42 PM Reply With Quote
If your turbo has ball bearings fitted it needs a restricter fitting to the oil feed pipe it cannot run on full oil pressure.
six mad
posted on 3/9/12 at 06:31 AM Reply With Quote
I am no engineer but I thought if you restrict the oil feed that will only increase the pressure.??
djtom
posted on 3/9/12 at 09:03 AM Reply With Quote
Air research is what Garrett used to be called back in the day. Sounds like you have got a standard RST turbo, I very much doubt that it's a ball bearing unit, in which case you shouldn't need a restrictor.
It's probably a touch on the small side for the zetec (originally intended for a 1.6l RST engine) but should provide low lag and good response - give it a try and see what you think!
Smoke could be knackered seals (unlikely if it's really been rebuilt) or just oil left over from the rebuild - leave it running for an hour to burn it all off.
Tom
six mad
posted on 3/9/12 at 07:43 PM Reply With Quote
Tom
Yes fingers crossed its residue, no ball bearings in this one, I had an EVO 9 GT with a BB turbo i know
what they sound like.
mcramsay
posted on 3/9/12 at 09:25 PM Reply With Quote
Hello mate, im currently in the planning stages for a turbo conversion on my zetec, is it possible you could up load some pics? also have you blanked off the breather that sits under the exhaust manifold? If so where have you relocated the breather to? Any info would be great! Sorry to hijack your thread!
[Edited on 3/9/12 by mcramsay]
six mad
posted on 4/9/12 at 06:01 PM Reply With Quote
Hi no problem, yes oem breather removed and blanked off mine has an 8mm pipe out of it which runs towards the gearbox(its tight behind the turbo) I am going to fit a catch tank next to the header tank.
How do you upload pics?
posted on 4/9/12 at 06:16 PM Reply With Quote
It will increase pressure upstream of the resitrictor, and decrease it downstream (turbo side).
mcramsay
posted on 4/9/12 at 06:38 PM Reply With Quote
Thanks mate, I'm not sure what you mean? You have blanked off the oem one by the engine mount on the exhaust side, where is this 8mm pipe attached to the block, if I u2u my email address can you send me some pics?
six mad
posted on 4/9/12 at 07:16 PM Reply With Quote
The 8mm pipe is drilled through/welded onto the blanking plate this is then piped to the oil catch tank.
Yes send your email i will take a pic for you.
mcramsay
posted on 4/9/12 at 07:28 PM Reply With Quote
Cheers mate, u2u sent
six mad
posted on 4/9/12 at 08:04 PM Reply With Quote
Arrh ok thanks for the confirmation
ss1turbo
posted on 5/9/12 at 12:45 PM Reply With Quote
Never a good idea to run it unconnected at any more than tickover IMHO - no restriction to the outlet air which could quite easily overspeed the turbo and destroy it in next to no time
Long live RWD...
six mad
posted on 5/9/12 at 05:14 PM Reply With Quote
Interesting I did not know that thanks for the heads up.
six mad
posted on 6/9/12 at 08:29 PM Reply With Quote
Update.
Had the car running again tonight and the smoking has stopped.
Still smoking a little from the outside of the turbo from oil residue, its amazed me how long it has taken to burn away.!!
Anyway on to the next job
