rabbit
posted on 7/9/12 at 05:51 PM |
bike carbs
looking for bike carbs & manifold for cvh, recently brought quantum fitted with 2ltr
cvh engine , anyone seen a set forsale ?
avagolen
posted on 7/9/12 at 07:57 PM |
I cannot help with the bits, but is it the same as a 1.8? Not heard of a 2.0 CVH.
If so you will have to ensure the inlet manifold you use blanks of the hole in the head
that allows the cooling water to go through the inlet manifold and get a thermostat
housing to bolt to the rear of the head where a core plug is at the moment. I have one if you want it.
If it is not a 1.8, ignore this info.......
HTH,
Len.
[Edited on 7/9/12 by avagolen]
rabbit
posted on 16/9/12 at 06:27 AM |
cvh
thanks for your reply. the engine is a ferriday engine based on 2lt tall block
fitted with 1600 head so i will not need to alter water system thanks for the
offer. ps i dont think ferriday build engines anymore but do some engineering work
still looking for manifold and carbs
[Edited on 16/9/12 by rabbit]
