Author: Subject: 3/4 unf x M12 ball joint, where from?
shaun fulcrum
posted on 10/9/12 at 07:40 PM Reply With Quote
As title. Need a new one for the lower joint on the front upright. I can't find one anywhere!!
Thanks for any help.
minitici
posted on 11/9/12 at 08:33 AM Reply With Quote
Why are you trying to mix metric and imperial?
I have not seen metric rod ends with the threaded shank bigger than the bore.
I have used imperial rod ends such as 5/8" bore 3/4" UNF shank.
If you need a 3/4"UNF male shank for the lower wishbone and need a 12mm bore for the bolt to the bottom of the upright then use a 5/8" x 3/4"UNF rod end and fit reducing spacers to 12mm ID.
McGill
[Edited on 11/9/12 by minitici]
shaun fulcrum
posted on 11/9/12 at 01:48 PM Reply With Quote
Thanks for that thinking it might not be M12 then
Here is a pic of mine (standard RAW fitting).
https://m.facebook.com/shaun.d.kemp?v=photos&__user=739528373#!/photo.php?fbid=10151140521493374&id=739528373&set=a.10151083626438374.4512 79.739528373&__user=739528373
Think it must be from a road car rather than a generic fit due to the shape?
minitici
posted on 12/9/12 at 07:31 AM Reply With Quote
Just has a look at your photo and now realise that you were asking about a ball joint rather than a rod end joint
The pin into the upright will be a taper pin - no doubt it is a readily available joint.
shaun fulcrum
posted on 12/9/12 at 11:05 AM Reply With Quote
Given up looking and went to RAW. £18 delivered may not be the cheapest but it fixes the car so I'm happy
