New Topic New Reply
Author: Subject: Zetec pulley help
YODI
posted on 12/9/12 at 11:41 AM Reply With Quote
Zetec pulley help
Hi Guys
Im spending the day going over my new purchase, yesterday I noticed that the pulley (on the left in pic) wasn't sitting well as the bolt was at an angle to the pulley, well I tightened it up a touch and it wouldn't turn so I took it all off and the bearing doesn't go all the way through the centre so if you tighten it you're actually squashing it and it had a couple of odd washers placed behind it I assume for spacing.
What have you guys used, any ideas other than making up a fresh pulley?
Thanks, Yodi
degmwilliams
posted on 12/9/12 at 11:56 AM Reply With Quote
I don't see why you need the left pulley, you should be able to just buy a smaller belt unless that's the only way you can tension it of course.
Building a tiger Avon st170 (slowly)
whitestu
posted on 12/9/12 at 12:06 PM Reply With Quote
+1
Do away with it and get a shorter belt.
Stu
Xtreme Kermit
posted on 12/9/12 at 12:08 PM Reply With Quote
Hmmm - is there an alternator?
posted on 12/9/12 at 12:16 PM Reply With Quote
Bottom right hand corner....
As suggested just take the pulley off and use a shorter belt..
YODI
posted on 12/9/12 at 12:47 PM Reply With Quote
+1
Stu
You're right mate after posting I sat there and thought about it with a cup of tea, exactly what I've done just waiting for parts
and yes the alternator is there lol
mike.williams1
posted on 12/9/12 at 02:49 PM Reply With Quote
Looking at the route of the belt if you remove the top pulley you won,t have enough belt to wrap around the water pump pulley.
femster87
posted on 12/9/12 at 02:55 PM Reply With Quote
Thats exactly what I thought.
loggyboy
posted on 12/9/12 at 02:57 PM Reply With Quote
But its the left pulley thats being suggested to be removed, not the top one!?
Mistral Motorsport
YODI
posted on 12/9/12 at 03:01 PM Reply With Quote
Its the left pulley, which is already off, new belt fitted and running lovely
degmwilliams
posted on 12/9/12 at 04:43 PM Reply With Quote
Nice one, bet it looks alot better too.
YODI
posted on 12/9/12 at 05:52 PM Reply With Quote
I think so
Xtreme Kermit
posted on 12/9/12 at 07:18 PM Reply With Quote
D'oh! Seems obvious now, funny how you're biased by your own setup...
Edited to say, looks better now!
[Edited on 12/9/12 by Xtreme Kermit]
Schrodinger
posted on 8/10/12 at 08:10 PM Reply With Quote
You havn't got much contact now with the Aircon? pulley (pulley with three bolts)
Keith
Aviemore
YODI
posted on 8/10/12 at 08:16 PM Reply With Quote
Aircon????
The pulley with 3 bolts is the water pump, its been changed again slightly as the idler gave way due to bad design so I fitted a new one and bracket and there's enough contact in my opinion.
YODI
posted on 8/10/12 at 08:17 PM Reply With Quote
This is the new idler/bracket set up
degmwilliams
posted on 8/10/12 at 08:21 PM Reply With Quote
It doesn't take much driving on the water pump.
degmwilliams
posted on 8/10/12 at 08:23 PM Reply With Quote
Isn't there room for the alternator on the other side? I'm doing a tiger Avon but have mine on the other side.
YODI
posted on 8/10/12 at 08:25 PM Reply With Quote
Its something I am going to look into but its working well at the moment, I think I'd need a smaller alternator and still dont think it would fit with the throttle bodies
[Edited on 8/10/12 by YODI]
New Topic New Reply
