Charlie_Zetec
| posted on 5/10/12 at 12:06 PM |
Carbon dash wtd - suppliers?
I've had a big change of plan with my dashboard, and having cut holes in it for switches and clocks that I now no longer wish to use, I need a
new dash panel. Annoying, as the one I got with the kit was also C/F, albeit not the best quality....
I've decided to bite the bullet and get another carbon fibre one, but I'm having trouble finding a supplier. Carbon Mods no longer
produce them, and didn't want to make me a single one-off.
I've found Fluke Motorsport
as an alternative supplier; has anyone on here used this German-based company?
And did I read somewhere that someone on here makes them up to spec.?
Car is a GTS W7DE (no additional comments req'd, thanks!), based upon McSorley +442 chassis. I can get exact measurements if required, but am
unsure if I want a flat-bottomed piece, or one with "ears" at this stage.
Any suggestions greatly received.
Thanks y'all!
big-vee-twin
| posted on 5/10/12 at 12:23 PM |
The carbon mods one was withdrawn as it didn't meet IVA requirements there was no radius on the bottom.
I've seen fluke and was considering them for a Tunnel top.
I used a grp blnk and covered it with Di-Noc.
Whats wrong with a GTS +4 - LOL!!
I just found this at SVC new I'd seen one recently carbon effect though linky
[Edited on 5/10/12 by big-vee-twin]
http://www.triangleltd.com
PAUL FISHER
| posted on 5/10/12 at 12:59 PM |
Julian a trader on here owns http://www.aerodynamix.co.uk/ top quality stuff
Charlie_Zetec
| posted on 5/10/12 at 01:02 PM |
A friend has a Carbon Mods one on his Westy, and it has a rounded bottom edge - they told me they withdrew it as they were focusing on other
components and projects?!?
Thanks for the SVC link though; I'll bear that in mind as a secondary option, as I really would prefer a proper C/F one to match the other
shiney bots on the car.
And thanks Paul, I'll check out Julians' website and see what he does!
Steve Hignett
| posted on 5/10/12 at 02:04 PM |
Assuming you haven't drilled holes on the radius part, why don't you get a bit of flat sheet and just put a strip straight across?
Either just straigh over the top or just cut the bottom curve off yours and bond the flat to a bit of ali and the curve below it and you've just
made your own CF dash???
If my description isn't very good (cos It's not!!!) then I'll draw you a simple "paint" drawing to explain...
Steve Hignett
| posted on 5/10/12 at 02:23 PM |
twybrow
| posted on 5/10/12 at 05:27 PM |
Depending upon when you need it, I have a mould, and I will be making myself a new one in the coming months (changing dash layout). It has a 25mm rad
on the bottom of the dash. See my photos for an example!
