Author: Subject: R1 carbs
smorse
posted on 10/10/12 at 12:43 AM Reply With Quote
R1 carbs
i have an 893cc blade with 38mm carbs, i notice that the R1 has 40mm carbs, would it be worthwhile switching over regarding power increase, can it be done?
r1_pete
posted on 10/10/12 at 07:13 AM Reply With Quote
Unless you have done porting, cam, valve work, and significantly increased potential engine power there is no point at all in changing to 2mm larger carbs.
mcerd1
posted on 10/10/12 at 07:41 AM Reply With Quote
I'm sure it could be done (anythings possible) but they are probably 38mm at the moment for a good reason
so unless you've done some major work to the engine that will require bigger carbs to feed it then you might actually loose power....
smorse
posted on 10/10/12 at 12:03 PM Reply With Quote
ok, i just assumed more fuel equals more power, i guess you need more air to go with it hence a turbo/ supercharger
mcerd1
posted on 10/10/12 at 12:26 PM Reply With Quote
there isn't a magic way to get more power for next to know cost/work...
unless an engine has a really bad feature that kill its performance (like the port shapes on a pinto head) then you'll need to change more than one thing to see any real gains and even then you always need to re-tune/re-map
