dirtysteve
| posted on 14/10/12 at 07:50 AM |
radiator??
hi folks, when i got my locost it had the pinto and gearbox, radiator removed, i've put my pinto and type 9 in but have no idea what radiator it
had or where it would be mounted, would there be a 'standard' rad used for the pinto or is it going to be trial and error?, your help
would be appreciated, steve
snapper
| posted on 14/10/12 at 08:03 AM |
Most use the Polo alloy radiator as upright as possible, boxed in to force all the air through
Fan behind is prefered if it will fit
You have the option to fit an 82 degree thermostat from Burton performance
With a standard Pinto you'll be ok, if you tune it then the 82 degree thermostat and an oil cooler will help
I fitted a 42 twin row steel from Boston radiators but this cost £140
If you look for polo rads on eBay I think the 1.9 desiel is the largest capacity
I eat to survive
I drink to forget
dirtysteve
| posted on 14/10/12 at 09:13 AM |
thats great, thanks
dirtysteve
| posted on 14/10/12 at 09:20 AM |
does it matter what year polo?
snapper
| posted on 14/10/12 at 09:31 AM |
I couldn't tell you what year that's why the engine capacity it was made to work on is a guide
Although most on here use a standard polo rad
You can have to little cooling, you can't have to much
If by any chance your engine ran cool its easy to remedy via thermostat or the racers trick of covering part of the radiator
The Pinto likes to run cooler than most of us realise, in most 7's it runs high 90's they prefer to run high 80's
I eat to survive
I drink to forget
rf900rush
| posted on 14/10/12 at 11:05 AM |
Hi
If you are any near epsom I have a surplus good used polo rad left over.
And a, I think Suzuki swift copper style rad.
dirtysteve
| posted on 15/10/12 at 09:29 PM |
thats great thanks, i'll bear that in mind if i cant find one localy, steve
Davg
| posted on 15/10/12 at 10:58 PM |
Location always helps
dirtysteve
| posted on 15/10/12 at 11:19 PM |
good point well put, essex, nr chelmsford, cheers, steve
Trollyjack
| posted on 16/10/12 at 08:37 PM |
click here
this normally fits
TrollyJack
