Author: Subject: Megasquirt Bluetooth
matnrach
posted on 19/10/12 at 09:28 PM Reply With Quote
Looking for bluetooth connectivity for my MS1 V3 initially for a laptop then an Android tablet.
The LM048/58 which looks as though it works seems expensive and the one on TS is also pricey when you include postage
The BT-232B-E on Ebay looks reasonable on price but has anybody used it successfully?
Do these need any hardware mods on the board?
matt_gsxr
posted on 19/10/12 at 09:53 PM Reply With Quote
I used that adapter and it worked fine.
Not sure whether the serial port on the V3 is wired up to power the adapter (I used a separate power supply, but I have earlier MS unit).
matnrach
posted on 19/10/12 at 09:56 PM Reply With Quote
Thanks for the info
I think that the RS232 port has 5v on one of the pins on the MS1 V3
matt_gsxr
posted on 19/10/12 at 11:03 PM Reply With Quote
scuderfish had a webpage with some information (a wiki thing) where I put some information.
I can't find it now, but I guess Dave will be along.
ashg
posted on 19/10/12 at 11:15 PM Reply With Quote
order one off efi analytics use code SHADOWDASH to get $10 off be quick as the deal expires on the 21st
[Edited on 19/10/2012 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
scudderfish
posted on 20/10/12 at 08:23 AM Reply With Quote
It moved when I changed over to github. It's now located here :-
https://github.com/scudderfish/MSLoggerBase/wiki/Adapters
matnrach
posted on 20/10/12 at 09:44 AM Reply With Quote
Do you know if it works with the Shadow android software?
scudderfish
posted on 20/10/12 at 11:36 AM Reply With Quote
No reason why not. If it works with one Android app, it should work with them all.
matnrach
posted on 20/10/12 at 12:08 PM Reply With Quote
Thanks for the help
I think I'll give it a go
matnrach
posted on 23/10/12 at 09:25 PM Reply With Quote
Did you make any hardware mods to make it work on the MS1 V3 i.e connect pins 7 and 8 of the DB9 together?
(To make a handshake for CTS and RTS)
[Edited on 23/10/12 by matnrach]
matnrach
posted on 4/11/12 at 03:59 PM Reply With Quote
All working now with the BT adaptor on a windows laptop and android phone/tablet
Seems to be the way to go now as it looks lots of new software will become available on Android
