bob tatt
posted on 21/10/12 at 08:45 AM |
random wheel question
hi there does anyone know if it is possible to fit some alloys with a pcd of 5x120 onto hubs with a pcd of 5x118. This is assuming the bore and offset
are correct. Is there such a thing as a wobble nut?
Thanks in advance rob
coyoteboy
| posted on 21/10/12 at 08:52 AM |
There's wobble bolts, not aware of wobble nuts existing. Wouldn't be impossible to make so its possible that they do exist.
theduck
| posted on 21/10/12 at 08:53 AM |
Yes there is, wobble bolts are horrid though. Better with adaptors.
[Edited on 21/10/12 by theduck]
bob tatt
| posted on 21/10/12 at 08:57 AM |
what do you meen by adapters?
loggyboy
| posted on 21/10/12 at 09:01 AM |
Wobble bolts are absolutely fine but you will NEED to have the correct centrebore or good spigot rings to ensure the wheel is centered on the hub.
Mistral Motorsport
SteveMX5
| posted on 21/10/12 at 10:11 AM |
1mm difference on each stud, get the file out
coyoteboy
| posted on 21/10/12 at 11:19 AM |
I'm presuming he has studs, which need nuts not wobble bolts?
Adapters will onlyy help if you wish to demolish your suspension/steering geometry. Unless of course you get wheels with an offset that counteracts
the adapter.
[Edited on 21/10/12 by coyoteboy]
chillis
| posted on 21/10/12 at 11:46 AM |
Wobbly wheel nuts/bolts have used them - 97.5mm to 100mm, no problems
Never under estimate the ingenuity of an idiot!
