Author: Subject: Want to remove my pinto dizzy and fuel pump
david_l_perry
posted on 25/10/12 at 10:12 PM Reply With Quote
My Pinto runs a Mega Jolt system and Bike carbs/bike fuel pump.
The original dizzy and fuel pump are doing nothing other than getting in the way.
I want to remove them both and spotted blanking plugs for the distributor from trigger wheels:-
blanking plug
Question for anybody that has done this :-
Can I just remove the Distributor and fuel pump and blank them over, or does anything else need removing
Ta in advance
Dave
[Edited on 25/10/12 by david_l_perry]
Mid life crisis made me buy a Robin Hood 2B, 2.1Pinto with ZX6 carbs - now fitted with a Jag SType 3.0 V6Loving it !
Dingz
posted on 25/10/12 at 10:25 PM Reply With Quote
Pump will be fine there will be a push rod which operates the pump that can be removed. The dizzy drives the oil pump so you can't just remove that, I think most people just shorten it I'm sure someone will be along to tell you how.
went on and on.
mcerd1
posted on 25/10/12 at 11:02 PM Reply With Quote
fuel pump is no problem - the stock EFI pinto's just have a blanking plate and no pushrod
burtons sell new blanking plates if you can't find a new one: linky
the dizzy is a different story, its also the oil pump drive ! (unless you have a dry sump)
you can cut it down, as long as you keep the top bearing, like this:
[Edited on 25/10/2012 by mcerd1]
david_l_perry
posted on 26/10/12 at 10:22 PM Reply With Quote
Thanks guys. On with the replacement cut down dizzy....well more accurately my father is turning it down for me. You have to keep the old folks busy !
mcerd1
posted on 29/10/12 at 08:40 AM Reply With Quote
what kind of dizzy is it ?
is it the points type or the electronic type ?
david_l_perry
posted on 29/10/12 at 09:02 AM Reply With Quote
Never had the top off...pretty sure its just the standard points though
The car was changed over to the Megajolt system long before I bought it
mitch2b
posted on 29/10/12 at 10:25 AM Reply With Quote
Dave, use the one i already had done, just machine to fit bearing, (dizzy is electronic, no points ) that reminds me must collect the spare as it belongs to Brian , in standish !
Mitch
mcerd1
posted on 29/10/12 at 10:52 AM Reply With Quote
if its got a vac. advance and electronic internals there is still a little bit of demand for these form places like H&H ignition (its the half way step between points and megajolt)
if its the points type not many people want them, but some one might so they sell for a few £ in working nick
and if its the late style electronic ones nobody wants these (no vac advance and only a HAL sensor for the ECU inside)
so they are worth nothing and the perfect candidate for cutting down
david_l_perry
posted on 29/10/12 at 11:50 AM Reply With Quote
Originally posted by mitch2b
.....that reminds me must collect the spare as it belongs to Brian , in standish !
Mitch
No worries Mitch
As soon as its replaced I will let you know and he can have the complete working dizzy unit back (the one that is still on the engine)
I knocked out the top bearing lining on the spare parts box dizzy and am using that rather than a separate roller bearing. So the dizzy bearing arrangement remains exactly as it always has been, only the shaft is shortened and a new cap will be sorted to cover it over.
Dave
david_l_perry
posted on 10/11/12 at 08:21 PM Reply With Quote
All done and working like a treat. The old man made quick work of boring out the cut down dizzy and remounting the top bearing.
I then cut down the original Dizzy shaft a couple of mm short of the top.
This was so that the rubber cap I was fitting over the top would not rub against the shaft, and it also gives a little reservoir for some oil to help keep it lubed.
The redundant fuel pump was replaced with a blanking plate
Top job and gets rid of two other parts of the engine that are taking up real estate
And here is a shot of my tight fitting black rubber knob that helps keep the lubed shaft clear of Dirt
