Author: Subject: water injection
beaver34
posted on 28/10/12 at 09:52 PM Reply With Quote
water injection
any one used water injection on there engine builds before to lower inlet temps?
looking for some info/feedback looking to use it on mine at some point
thanks
needforspeed
posted on 28/10/12 at 10:20 PM Reply With Quote
what do you want to know?
Davegtst
posted on 28/10/12 at 10:28 PM Reply With Quote
I had it on my skyline. It won't give you any more power but it will allow you to increase boost safer as it will cool the inlet air and reduce det. It's a good option if you dont have any room for a intercooler.
[Edited on 28/10/12 by Davegtst]
beaver34
posted on 28/10/12 at 10:30 PM Reply With Quote
what kits people are using and real world results ideally
thanks
Autosri
posted on 29/10/12 at 12:52 AM Reply With Quote
i use water/meth on my nitrous daily car for knock protection i bought a pump on ebay that does 80psi and used a screen wash pump as a priming pump and now does 160psi with the regulating switch dissconnected i use 4mm nylon line through the car which is just normal airline so cheap and i bought an aquamist nozzle direct as they are the best atomizing nozzles available and i had a spare nitrous solenoid so use that close to the nozzle
westy turbo
posted on 3/11/12 at 07:49 PM Reply With Quote
Using a snow performance dual nozzle kit and my inlet temp is the same with ambient air temp.
[Edited on 3/11/12 by westy turbo]
beaver34
posted on 3/11/12 at 08:18 PM Reply With Quote
I've just won one of there stage 2 kits, but it has no nozzle so need to get one
Where do you run yours and is yours intercooler also?
westy turbo
posted on 4/11/12 at 04:59 AM Reply With Quote
Both on inlet + intercooler.
beaver34
posted on 4/11/12 at 09:49 AM Reply With Quote
is it this kit
http://www.snowperformance.net/stage-2-boost-cooler.html
also how did you work out what size nozzles to use for your application?
this is my setup at the moment, any input on where is best and why would be good
westy turbo
posted on 5/11/12 at 02:03 PM Reply With Quote
Thats what they recomend
Step 3 Nozzle Selection
Nozzle sizing is a function of horsepower, which approximates the
engine airflow, and boost, which approximates intake charge heat.
Recommended starting points:
250 - 350 WHP 625 ml/min nozzle
400 - 500 WHP 375 & 625 ml/min nozzle
500 - 600 WHP 2 X 625 ml/min nozzle
what HP are you aiming for?
I would have a read on it any way,
http://www.snowperformance.net/product_images/product_variation-installation_pdf-40.pdf
[Edited on 5/11/12 by westy turbo]
westy turbo
posted on 7/11/12 at 10:54 AM Reply With Quote
