Author: Subject: Where to get Princess 4 pot spacer kit ?
DaveFJ
posted on 17/9/04 at 12:47 PM Reply With Quote
As the title suggests... where can i get a spacer kit for my princess 4 pots to fit capri 2.8 vented disks on my Cortina uprights ??
Also there seems to be some talk of the thickness of the spacers (6,8,9 or 10mm ?)
Dave
timf
posted on 17/9/04 at 01:09 PM Reply With Quote
www.peterlloydrallying.co.uk
phelpsa
posted on 17/9/04 at 04:11 PM Reply With Quote
Burton Power do them too.
Adam
DaveFJ
posted on 17/9/04 at 04:22 PM Reply With Quote
Anyone know about the thickness issue ?
apparently BP do them in 6,8 & 10 mm ???
Dave
Steve Hnz
posted on 17/9/04 at 10:39 PM Reply With Quote
Depends on the thickness of your replacement discs against your original ones. From the brakeparts int catalogue
http://www.brakeparts.co.uk/ the cortina ones are 13mm & the capri vented ones are 20mm so a spacer of 8mm would seem your closest bet. the original princess discs were also 13mm thickness. HTH Cheers, Steve
ned
posted on 20/9/04 at 08:38 AM Reply With Quote
rally design also do them, raldes.co.uk
Ned.
beware, I've got yellow skin
Hugh Jarce
posted on 21/9/04 at 03:44 AM Reply With Quote
Incidently, if you can't find princess callipers, the inner halves from a Triumph 2000 and the outer halves from a Hilman (or is it vice versa - I forget) make up a Princess calliper.
An old trick from my MGB brake conversion days!
The pay isn't very good , but the work's hard.
DaveFJ
posted on 21/9/04 at 07:36 AM Reply With Quote
Thanks everyone for your help, I have ordered my spacer kits from Peter Lloyd (£29.99)
when you add the seal kits and caliper paint and 6 new bleed nipples my 'bargain' calipers have all of a sudden cost me a small fortune! (well about £120 anyway)
Dave
ned
posted on 21/9/04 at 08:41 AM Reply With Quote
still half the price of the outlaw m16 alloy calipers, though about twice the weight
Ned.
DaveFJ
posted on 21/9/04 at 08:55 AM Reply With Quote
the weight issue isn't as bad as some would have you beleive.. they are only fractionally heavier than standard M16's (obviously not alloy ones)
which by the way I now have a set of going cheap! (as removed from donor)
Dave
