mark chandler
posted on 4/11/12 at 09:23 AM |
BEC live axle prop
Hello chaps
What format of prop do you use with a live axle?
Split/single prop, where is the sliding joint and which way does it point. Pictures if possible please
Thanks Mark
zekill
posted on 4/11/12 at 09:40 AM |
I'm use a two piece shaft, TRT on second part and sliding at the rear.
It seem to be the standard setup.
Full lenght is about 1300mm
Fisher Fury with Phoenix bodywork, Blade 919cc
Nick DV
posted on 4/11/12 at 10:17 AM |
Hi Mark,
A two piece set up is best. Try these people http://www.baileymorris.co.uk/
Cheers, Nick
"The force will be with you, always!"
renetom
posted on 4/11/12 at 10:31 AM |
props
This is what we used
![](/galpreviews/) ![](/gallery/)
