Author: Subject: Reverse on Sylva ZX12R
HPDxxx
posted on 20/11/12 at 09:40 AM Reply With Quote
Hello,
my friend looking for install a reverse gear in his sylva powered by ZX-12R engine.
i have checked his chassis but there is very little space.
Less then 6 inch around rear diff flange (<3" radius).
while near front output flange, the space is less... about <1 inch between flange and water pump or chassis..
some one has installed reverse gear on this car?
in your opinion it's possible to do?
thanks
renetom
posted on 20/11/12 at 10:02 AM Reply With Quote
Reverse
Hi
If you don't have the room for an electric one.
The only other option is a reversing box & 2 propshafts.
Not cheap but better than electric (only my opinion)
Good luck
René
40inches
posted on 20/11/12 at 10:08 AM Reply With Quote
I along with many others have used a VAG starter motor and a spur gear fitted to the diff flange.
Most use Sierra running gear, but it would be possible to adapt to other types. I should say that this system will not
get you very far reversing up a slope. Some info in my photo archive.
HPDxxx
posted on 20/11/12 at 10:24 AM Reply With Quote
thankyou for your fast reply!
@ renetom
my friend have a reverse gear box from his old westfield...
if the electric version would be impossible to achieve we will use it.
@ 40inches
thanks for input, how much is diameter of bigger cogwheel in this photo?
[Edited on 20/11/12 by HPDxxx]
40inches
posted on 20/11/12 at 10:29 AM Reply With Quote
@ renetom
@ 40inches
5.5 inches I had to form a slight bulge in the side panel for the motor bracket.
HPDxxx
posted on 20/11/12 at 12:53 PM Reply With Quote
omg
thats sound perfect! where come from your biggest gear?
bodger
posted on 20/11/12 at 01:22 PM Reply With Quote
U2U sent
40inches
posted on 20/11/12 at 04:05 PM Reply With Quote
omg
HPC Gears http://www.hpcgears.com/newpdf/spurgears_12dp.pdf you need the G12-64 machined to this drawing:
This is for Ford Sierra running gear.
