Author: Subject: Alternative to indicator stalks
cjwood23
posted on 29/11/12 at 04:57 PM Reply With Quote
Guys,
Remember a post a while back (either here or PH) which had a control box and buttons for the indicators.
Can anyone remeber/recommend anything?
______________________
Chris
wilkingj
posted on 29/11/12 at 05:02 PM Reply With Quote
Hand Signals???
Best Regards
Geoff
http://www.v8viento.co.uk
rdodger
posted on 29/11/12 at 05:46 PM Reply With Quote
This topic?
http://www.locostbuilders.co.uk/viewthread.php?tid=161097
posted on 29/11/12 at 06:24 PM Reply With Quote
You can also get get1950's style indicator knobs with clockwork timers the switch mounts through the dashboard.
Davegtst
posted on 29/11/12 at 06:57 PM Reply With Quote
I've got an on/off/on toggle switch just behind the gear lever. Much better than using an old sierra one imo, the only problem is i keep leaving it flashing as it can't self cancel.
loggyboy
posted on 30/11/12 at 10:52 AM Reply With Quote
This one?
http://www.locostbuilders.co.uk/viewthread.php?tid=155057
Mistral Motorsport
bbwales
posted on 30/11/12 at 11:48 AM Reply With Quote
I used non-latching push buttons on my steering wheel one red and the other green (have done sailing in the past) connected to a Signal Dynamics self cancelling module
http://signaldynamics.com/index.php/products/led-lighting?page=shop.product_details&flypage=flypage.tpl&product_id=36&category_id=43 />
it worked a treat, the only shortfall was the contacts at the back of the switches were tiny and did break a couple of times. the switches were connected to a curly wire with a connector on it so I could remove the steering wheel.
Regards
Bob
Not Anumber
posted on 28/1/13 at 10:00 PM Reply With Quote
I gave up and realised that column stalks wereby far the most practical for road use being the only way they could self cancel. I then went further and transferred the headlight switching to the stalks too. Up until then the lights were on two switches on the dash which made flashing the lights pointlessly difficult.
steve m
posted on 28/1/13 at 10:09 PM Reply With Quote
"I've got an on/off/on toggle switch just behind the gear lever. Much better than using an old sierra one imo, the only problem is i keep leaving it flashing as it can't self cancel."
+1
exactly as mine are
posted on 28/1/13 at 10:35 PM Reply With Quote
I fitted a really annoying buzzer on mine so it didn't need to self cancel
