New Topic New Reply
Author: Subject: Cad drawings
BenBrooks
posted on 3/12/12 at 07:04 PM Reply With Quote
Cad drawings
Has anyone got any cad drawings of Haynes roadster/ sierra parts. I've found a 3d printing company doing Steel titanium and aluminium and thought I'd amuse myself with a quote.
Ben
PSpirine
posted on 3/12/12 at 07:13 PM Reply With Quote
A pair of front uprights in aluminium will be about £10-15k as an estimate (can't imagine it costing much less than CNC machining for something like an upright). Enjoy
BenBrooks
posted on 3/12/12 at 07:16 PM Reply With Quote
like i said, simply amusing myself as this 3d printing is pretty cool stuff.
bi22le
posted on 3/12/12 at 07:18 PM Reply With Quote
I dont find £10K very funny!!
Oh wait, each?
Yeah, thats funny.
Ill have some for the back end too please Santa!
Please read my ring story:
balidey
posted on 3/12/12 at 08:26 PM Reply With Quote
From what I've seen of 3d printed alloy, its nowhere near like the strength you would expect from a die cast or machined alloy piece.
So you may as well get a quote for the plastic rapid prototype items, it'll be just as relevant.
Dutch bears have terrible skin due to their clogged paws
coyoteboy
posted on 3/12/12 at 09:44 PM Reply With Quote
Done properly it'll be ~80% normal strength at least. But that's done properly, on a machine costing half a million quid. And it'll cost in the region of 10-15K PER upright, at least, again if done properly.
I could understand it if you were planning to make a 1:20th scale model!
I've recently been quoted £150 per upright to machine from billet, personally seems like more sense
phelpsa
posted on 3/12/12 at 11:40 PM Reply With Quote
It can be very strong, but as it is more similar to sintered materials they tend to be very brittle and not very good in fatigue.
One interesting use of it is in the roll hoop of a F1 car where fatigue isn't an issue (it's only ever loaded once!)
coyoteboy
posted on 4/12/12 at 12:32 AM Reply With Quote
Indeed, the granular structure tends to cause fatigue problems due to micro crack propagation. SLM is less prote to it than SLS but still applies.
designer
posted on 4/12/12 at 09:30 AM Reply With Quote
3D printers are excellent to make a former in plastic to make the mould to cast a proper part.
coyoteboy
posted on 4/12/12 at 10:22 AM Reply With Quote
That's very true, but it is a historic view really.
vanepico
posted on 5/12/12 at 05:58 PM Reply With Quote
If you're talking about something like alumide which is a mixture of aluminium and plastic it will be very brittle, but it says it can be ground, drilled and finished, on the datasheet.
I can't imagine how they can 3D print something out of solid metal without it heating to 1000+*c
[Edited on 5/12/12 by vanepico]
__________________________
Will CAD for food/money/beer...
phelpsa
posted on 5/12/12 at 06:08 PM Reply With Quote
Not talking about alumide, thats a very different material (and not a particularly nice one!).
3D printing in metal is now commonplace. It is fused in layers of 20-30 microns with a laser.
vanepico
posted on 5/12/12 at 06:18 PM Reply With Quote
I'm pretty sure even then it is fused by a UV sensitive glue which isn't going to be as strong as actual metal
phelpsa
posted on 5/12/12 at 07:15 PM Reply With Quote
Nope. The metal is fused together.
coyoteboy
posted on 5/12/12 at 07:16 PM Reply With Quote
You can be as sure as you like, but you're wrong (Good friends with someone who designs and makes the machines).
For info, titanium F1 roll hoop designed to withstand 120kN frontal impact while weighing 1kg, made entirely this way:
SLM machines are ace
https://www.youtube.com/watch?v=4odUhDjKHzo
[Edited on 5/12/12 by coyoteboy]
bi22le
posted on 5/12/12 at 07:23 PM Reply With Quote
So how do they then bolt the roll hoop on?
coyoteboy
posted on 5/12/12 at 07:25 PM Reply With Quote
I've no idea, though I suspect they have a set of threaded holes underneath. Or maybe it's incorporated into a composite structure, since you can make less than 100% dense materials you could allow a metal/composite boundary to merge and couple nicely. (That's not my photo and I didn't see that being made, but I have seen many other parts made that way)
sylva_phoenix
posted on 20/12/12 at 09:01 PM Reply With Quote
I just had a quote back from a casting specialist who wanted £9000 for a one off turbo manifold. Think I'll be fabricating that myself then....
coyoteboy
posted on 20/12/12 at 09:07 PM Reply With Quote
Cast it yourself? Get collecting coke cans.
blakep82
posted on 20/12/12 at 09:13 PM Reply With Quote
i flasers can be used to cut metals, i wonder if 2 lasers are used on a sort of X and Y axis, and where they cross is hot enough to melt the metal on to the last layer? i think like how these work maybe?
http://www.youtube.com/watch?v=8HRyvCOZ2eM
New Topic New Reply
