djtom
posted on 5/12/12 at 08:41 PM |
Garage clearout - R1 exhaust and useful bits
Pre-Xmas clearout.
All prices include postage.
Modified R1 carbon exhaust from a 1998 4XV model. This has had the tailpipe removed, the end of the can cut off, the baffles were then removed and the
end of the can was then rivetted back in place. This will be much more free flowing than the standard can (the baffles are very restrictive). Should
sound nice too! The link pipe on this is stainless, not titanium like the newer models, so will be easy to modify/weld for your needs £50 posted
VDO 2-wire Idle Air Control Valve. Was being used with my Megasquirt EFI conversion, I've now changed to a different system. Will work with most
aftermarket ECUs. £10 posted
Tiny windscreen washer pump. £5 posted
5mm universal wheel spacers. £5 posted
Bosch 3 wire Idle Air Control Valve. Was being used with my Megasquirt EFI conversion, I've now changed to (yet another) different system. Will
work with most aftermarket ECUs. £10 posted
Starter Solenoid from an Xflow engined car. Pretty much as new. £5 posted.
Tom
joni
posted on 5/12/12 at 11:18 PM |
wheel spacers
hi i will take the wheel spacers plz let me no how to pay thanks jonny
djtom
posted on 6/12/12 at 12:04 AM |
Sorry Jonny, wheel spacers already sold via U2U to bobthebuilder.
Everything else still available.
