Author: Subject: Xflow head work for bike carb conversion
matto_89
posted on 17/12/12 at 08:10 PM Reply With Quote
Hi All,
Have had the 7 that my old man and I built on the road since this summer, and we're converting the X-Flow from a twin choke weber to bike carbs over the winter. We rebuilt the bottom end before putting it in, but we've not touched the head. We've got a BCF2 cam in it. In terms of the head, a bit of research suggests larger exhaust valves and general work to improve the flow, and we'll also get it converted to run unleaded. Any further recommendations?
Thanks in advance,
Matt
clairetoo
posted on 17/12/12 at 08:55 PM Reply With Quote
Simple recipe for good power is the biggest valves you can get (1 5/8 inlet / 1 3/8 exhausts) , then double valve springs and steel rocker posts for reliability .
Its cuz I is blond , innit
Claire xx
Will weld for food......
puma931
posted on 18/12/12 at 08:45 AM Reply With Quote
Take a look at this link for details of my 1.3 xflow running bike carbs
http://www.locostbuilders.co.uk/viewthread.php?tid=174211
sylva_phoenix
posted on 20/12/12 at 09:11 PM Reply With Quote
Depending upon how much lift your cam gives you, you may need to pocket the pistons for clearance.
