Author: Subject: Rosejointed crossflow alternator bracket
philfingers
posted on 20/12/12 at 09:42 AM Reply With Quote
Made a alternator bracket adjuster with some rod ends and hex bar which I turned down in the lathe. Came out well, alternator wasn't aligned so spent more time getting that right than making the adjuster. It has LH and RH rod ends, so very easy to adjust, just twiddle it to the right tension and nip the nuts up! Using a 800mm belt.
Here's the pics
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
Dick Axtell
posted on 20/12/12 at 09:56 AM Reply With Quote
OoooH!!!! Nice. That's definitely a "Like".
So where did you get LH rose joint? Pls advise.
I shall be fiddling in this area - (when the weather warms up!).
[Edited on 20/12/12 by Dick Axtell]
Charlie_Zetec
posted on 20/12/12 at 09:58 AM Reply With Quote
Now I saw Ford Pinto/Xflow/Crossflow Adjustable Alternator Bracket (Red) on eBay the other day and thought it was a great idea! I was considering buying one for my Zetec install, but holding fire for the moment.
Out of curiosity, how much would you say it cost you in terms of materials, time etc.? Could be a market for this....
loggyboy
posted on 20/12/12 at 10:10 AM Reply With Quote
Very neat and tidy.
McGill Motorsport is a good source of RJs. They also make premade turnbuckles:
linky
Mistral Motorsport
posted on 20/12/12 at 10:31 AM Reply With Quote
Got to be better than what Ford fitted.
philfingers
posted on 20/12/12 at 11:03 AM Reply With Quote
Seeing as there’s so many posts in an hour! I could do them for £14.00 inc recorded delivery, payment into bank account, £14.60 with paypal. Cheaper than £28.50 on ebay!
The stock one will be sized for crossflow with 800mm belt, as mine is BUT you could extend them by 1.5”ok. Can be made to length tho for other applications
LMK if you’re interested and I’ll order more material
STM Phoenix R1
paulf
posted on 20/12/12 at 12:03 PM Reply With Quote
I made something very similar a while ago for my alternator.As I didn't have a left hand tap at the time I just used 2 RH threaded rose joints and drilled the hex bar clearance at one end and tapped the other end. This means that the belt tension holds it together but never had a problem .
Paul
loggyboy
posted on 20/12/12 at 12:16 PM Reply With Quote
Are the £5 McGill ones no good then?
Mistral Motorsport
philfingers
posted on 20/12/12 at 12:19 PM Reply With Quote
Sorry, should elaborate. Mcgill ones all too long- for cross flow anyway, mine is 2.25" I think.
Good LH tap is £20
You don't need a lathe to machine them but easier and more accurate.
STM Phoenix R1
loggyboy
posted on 20/12/12 at 12:34 PM Reply With Quote
Good LH tap is £20
Fair enough. Is that centre to centre or the main shank thats 2.25"?
Mistral Motorsport
philfingers
posted on 20/12/12 at 12:53 PM Reply With Quote
the hex bar is 2.25" ish!
STM Phoenix R1
Dick Axtell
posted on 20/12/12 at 01:00 PM Reply With Quote
Definitely interested, seeing as I've also got Xflow. U2U in your inbox.
blakep82
posted on 20/12/12 at 02:45 PM Reply With Quote
mcgills for rod ends, and in fact they sell the linkages too, not too expensive either.
http://www.mcgillmotorsports.co.uk/index.php?act=viewCat&catId=33
________________________
loggyboy
posted on 20/12/12 at 02:55 PM Reply With Quote
Must be an echo.... lol
Mistral Motorsport
blakep82
posted on 20/12/12 at 03:14 PM Reply With Quote
echo echo echo
yeah, i saw that after lol, didn't read the whole thing, i've not got all day
Mr Whippy
posted on 20/12/12 at 04:26 PM Reply With Quote
great idea will use that myself
sylva_phoenix
posted on 20/12/12 at 08:52 PM Reply With Quote
nice work.
wonderfulweasel
posted on 21/12/12 at 12:59 AM Reply With Quote
Looks neat. I'm interested in one. I'll send you a u2u.
philfingers
posted on 21/12/12 at 09:11 AM Reply With Quote
ordered more parts yesterday for another 7 kits, will update when they're available
STM Phoenix R1
philfingers
posted on 21/12/12 at 10:12 PM Reply With Quote
Ok, for those that have expressed an interest I have 5 made up
These are £14.60 if paying by paypal or £14.00 if paying by bank transfer
If you wish to pay my midnight tonight then can mail them 1st class recorded tomorrow
They're are 100mm wound right in and fit my crossflow with stock pulleys and 800mm belt, which in the striker clears the bodywork on the nearside
STM Phoenix R1
