Author: Subject: Type9 Reverse Detent
DH2
posted on 2/1/13 at 10:08 AM Reply With Quote
The block in the tailhousing on my Type9, which is part of reverse detent mechanism (in conjunction with the lever), is missing.
I have a spare box, but cannot fathom a good method to get the damn thing out?
Or where I might procure a replacement?
DH2
phil m
posted on 2/1/13 at 10:30 AM Reply With Quote
if it's the same as the 4 speed box, then take out the gear lever and you should be able to see it through this hole. Then use a long drift to tap it out backwards.
alladdin
posted on 2/1/13 at 10:39 AM Reply With Quote
DH2
if your after the plastic saddle part, i see them on ebay.
DH2
posted on 2/1/13 at 11:11 AM Reply With Quote
I have the lever out, but I cannot get any purchase on the detent block to be able to whack it out... I can see I may have to fabricate something to be able to get a puller on it, which would be a bit tedious.
No, not the saddle, there is a metal block which should be in that slot to the top right of my photo - this stops the lever in the 1st-2nd gear plane, unless you push down to get over to reverse. Right now, it's not at all easy to get 1st!
DH2
alladdin
posted on 2/1/13 at 11:57 AM Reply With Quote
ok, got you now.
can you drill/tap and use a slide hammer ?
phil m
posted on 2/1/13 at 12:38 PM Reply With Quote
Think it's one of these
[img][/img]
[Edited on 2/1/13 by phil m]
DH2
posted on 2/1/13 at 03:19 PM Reply With Quote
That's where it went!!!
I've been struggling to think why anyone would want to remove it...
posted on 2/1/13 at 04:22 PM Reply With Quote
I removed mine by first removing the rear cover by tapping a "drift" from the gearstick side (my drift was actually a length of wood - the cover is only a stamped bit of tin). Then I put a long steel bar through the gearstick hole, held the bottem end against the end of the detent and smacked the bar with a hammer, just above the gearstick hole. This should shift the detent as it's only wedged in.
One warning - when it does shift it will fly across the garage and probably land in the most inconvenient place! (voice of experience).
note: easier to do than explain...
DH2
posted on 2/1/13 at 06:03 PM Reply With Quote
Thanks. I tried that by leaning on a gert-big screwdriver. Might need to try something a bit more brutal, but access through the top hole is a bit limited.
DH2
perksy
posted on 2/1/13 at 07:08 PM Reply With Quote
They can be a bugger to get out
Last one i did i used my multitool to grind a small 'slot' in it and then knocked it out with a drift
posted on 2/1/13 at 10:16 PM Reply With Quote
DH2
It won't lever out... I used steel bar around 15mm x 5mm to get behind the detent. The bar was around 1 metre long - I held the top, and hit it as low as I could manage. It's quite violent when it does go!
