Author: Subject: hose reducer
joni
posted on 2/1/13 at 09:45 PM Reply With Quote
hose reducer
hi iam looking a hose reducer i want a 25 mm pipe with a 17mm t of the 25mm pipe dose any one make these or no were i would get one regards jonny
rdodger
posted on 2/1/13 at 10:00 PM Reply With Quote
Try CBS. They do lots of sizes of T
posted on 2/1/13 at 10:26 PM Reply With Quote
17mm is an unusual size the standard automotive hose sizes are converted from US inch sizes so you will see them 15mm or 16mm and 19mm or 20mm
The hose fittings sold for Koi carp pomds and irrigation systems work fine in automotive coolings systems.
Be aware some of Koi Carp fittings are sold on outside diameter of the thin wall plastic tubiing used for Kpi carp water systems.
This might be a low cost solution
25mm-20mm Flexi Pond Pipe Reducer 1"' to 0.75"' Inch Hose
If the pipe fitting is loose in the hose then a locost trick is stretching a short piece of rubber cut from a bicycle inner over the barb of the hose fitting will help get a good tight fit. You might need to use a 2 or three layers of inner tube rubber to get a snug fit, a dusting of French Chalk (ie Talcum powder) helps get the hose on.
joni
posted on 2/1/13 at 11:25 PM Reply With Quote
cbs ???
CBS ???? WHAT DO I GOOGLE thanks jonny
Davg
posted on 3/1/13 at 12:15 AM Reply With Quote
http://www.cbsonline.co.uk/
skodaman
posted on 3/1/13 at 12:42 AM Reply With Quote
All pond fittings we sell at work are in imperial internal diameters 1/2,3/4, 1, 11/4 and 1.5 inches. This is commonest way for pond stuff in UK. Any of the aquarium pipe work is usually metric. There are adaptors that can convert anything from 1/4 inch up to 11/2 inch and anything inbetween.
Skodaman
