Author: Subject: Diff repair opinions
sdh2903
posted on 6/1/13 at 06:48 PM Reply With Quote
Hi All
Last year I took a punt on a cheap M3 LSD, Opened it up today with the intention of starting to strip it as the bearings are shot. However I found that 2 of the lugs on one of the internal flanges have broken off as you can see in the pic below:
diff
diff
This is how the flange should look:
diff2
diff2
Is this repairable or should i just bin it? The flange is cast so presume if it can be repaired it would need lugs Tig welding on?
fregis
posted on 6/1/13 at 07:21 PM Reply With Quote
if you produce disc which is mounted on you all the bolts. Pressure it higher flatness and do not need to weld
or make |_ _|
[Edited on 6/1/13 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
sdh2903
posted on 6/1/13 at 07:37 PM Reply With Quote
Ahh good idea, make a doubler ring to fit over the top and fit some longer bolts. Cheers for that!
If it was only 1 missing i probably would just leave it, but, as the 2 are next to each other it definitly needs sorting.
snapper
posted on 6/1/13 at 08:04 PM Reply With Quote
Welding cast is not simple
The process is very involved not a simple case of mig or TIG especially as there are some serious forces going through a diff
I eat to survive
I drink to forget
sdh2903
posted on 6/1/13 at 08:22 PM Reply With Quote
Agreed, would you anticipate any issues with using a retainer ring over the top?
umgrybab
posted on 6/1/13 at 11:57 PM Reply With Quote
A retainer ring is more likely to back off over time and then that leaves the piece open to simple fracture. Welding is not simple but its not at all difficult in the great scheme of things, I mean you're building your own car. Welding and a retainer ring may be the best solution, but I'd be sure to lock wire those bolts. They've been loosened off and the cast sheared once so there's a good chance the housing is slightly oblong in those locations.
trextr7monkey
posted on 7/1/13 at 12:48 AM Reply With Quote
Although we have a decent welder any critical jobs like this are entrusted to local engineer/blacksmith who tends to be doing this kind of stuff on a regular basis - not expensive and he knows exactly how to preheat components so no stress in finished work etc
I'd try and suss out someone of similar calibre in your locality
atb
Mike
cliftyhanger
posted on 7/1/13 at 07:06 AM Reply With Quote
However, worth having a think about this. Where are the missing bits if not in the diff somebody may have been in there before and given up. Likewise the bearings, plus how are the CWP??
It may have been sold on as it isn't worth repairing. I have no idea how much they fetch, but you may be better off just buying a good one?
sdh2903
posted on 7/1/13 at 08:07 AM Reply With Quote
All offending missing bits were in the oil, judging by state of gasket and how tough it was to get the back plate off I would say its not been open in a long while. It definitely needs further stripping and checking before committing to any repairs.
It's getting to be a pretty rare diff as its from a 3.0 non evo M3 with a 3.15 ratio. They fetch anywhere from 200 up to 4-500 for a real good one so it's worth pursuing.
Oddified
posted on 7/1/13 at 10:04 AM Reply With Quote
I would say just make a complete new end piece out of steel, then it would be 100% right.
Ian
MarcV
posted on 7/1/13 at 12:28 PM Reply With Quote
Wouldn't it be possible to grab this part out of another diff? Or is it specific to the M3 diff?
bi22le
posted on 7/1/13 at 12:32 PM Reply With Quote
That was my thoughts. There must be busted M3 diffs out there that have this peice intact.
Please read my ring story:
sdh2903
posted on 7/1/13 at 01:45 PM Reply With Quote
This had crossed my mind as its only a bearing race flange really, it also looks very similar to the one in my open diff. I'm just trying to get my copy of Bmw TIS working to see if I can cross reference the parts. Realoem used to have the exploded parts diagram but not any more.
I'm going to pull the drive flanges and the lsd out later and have a good look at everything to see if anything is chewed up and re-assess whether its scrap or not.
sdh2903
posted on 7/1/13 at 08:08 PM Reply With Quote
Well cracked it open and split it apart today. Not only was there the 2 bits of casting but also one of the allen bolt heads had sheared off! (did come out easy though)
diff3
diff3
diff4
diff4
Checked over the CWP, pinion and all the internals and there are no marks on any teeth so i suspect none of the metal chunks have been through the gears. However the clutch plates do look a bit worn.
diff5
diff5
diff6
diff6
The cause of the graunching was the input shaft bearing, it was completely shot, i suspect through incorrect torqueing and the fact that the dust cover and seal were bolloxed.
I'm going to drop it into a local diff/gearbox place but I suspect its going to be too pricey. Ive done some research and the bearings are around £100 for the proper SKF items and the clutch plates are £94+shipping+import tax plus £30 for dust covers and a bit more for some decent oil. So with the cast repair plus an overhaul I suspect I won't see change from £400+
I think I will keep the CWP and pinion then I can swap them into my open diff as they are all interchangeable.
[Edited on 7/1/13 by sdh2903]
