Author: Subject: Speedo healer
Rogthebandit
posted on 6/1/13 at 08:55 PM Reply With Quote
Speedo healer
How do.
I contacted a seller on ebay regarding a speedo healer for a gixxer 1000 k6 in my indy. He said it wasnt suitable for car installations? Is that correct? It was the v4 model healer. Has anyone else had problems using the healers?
Rog
wylliezx9r
posted on 6/1/13 at 09:00 PM Reply With Quote
Worked fine for me, I calibrated it using the speed dispalyed on my sat nav, there is a page on the speedohealer website that works it all out for you.
George Best
daniel mason
posted on 6/1/13 at 09:04 PM Reply With Quote
healtech v4 are what most use to caliberate clocks.i prefer standalone dash so sold 2 a while back!
contact malc at yorkshire engines,he may have some kicking about!
Rogthebandit
posted on 6/1/13 at 09:08 PM Reply With Quote
Cheers for the feedback guys. I will try malc. Thanks
cosmick
posted on 6/1/13 at 09:13 PM Reply With Quote
there is only a bike speedo healer and my one works perfectly in the car. Are you using the standard speedo in your dashboard? If so, the position I took the readings from was the 4 bolts on the front propshaft adapter using the genuine Suzuki speedo pick up.
If it can't be fixed with a hammer then its probably an electrical problem.
wylliezx9r
posted on 6/1/13 at 09:15 PM Reply With Quote
healtech and speedohealer are the same thing, Healtech is the manufacturer of the speedohealer.
George Best
daniel mason
you can get healers for the honda s2000 motor. i had one before i got the dash2. yellow jacket i think it was called
Rogthebandit
posted on 6/1/13 at 09:29 PM Reply With Quote
Ya, im using the standard k6 clocks. I havent mounted the pick up yet, i was planning the same place you mention on the front flange. What sort of gap do you need to get it to read?
cosmick
posted on 6/1/13 at 10:27 PM Reply With Quote
When I said there is only a bike speedo healer, i meant for the GSX R models. As for the pick up, if you look at my photo archive, you can see how i mounted it. it needs a gap of aout 0.5mm to 1mm if I remember. also, i used the round head of the bolt to act as the pulse not the nuts as shown in the photo. Just turned the bolts around to get the same distance for each bolt head.
daniel mason
posted on 6/1/13 at 10:53 PM Reply With Quote
speedtuner make a speedo healer for gsxr's i had one. not that it matters.
