Author: Subject: Who can recondition my rack with my quick rack bits?
The Venom Project
posted on 8/1/13 at 09:04 PM Reply With Quote
Hello,
I have a set of quick rack internals, and I need someone to fit them into an old rack I have that I am stuck pulling apart.
I have an old rack, but all the bits are rusty crap, and it wont split. I am happy to fedex my parts to someone.
I am also willing to buy a recon rack, if the seller will strip it and fit my quick rack.
Nick
It's not that i'm lazy, it's that I just don't care.....
phelpsa
posted on 9/1/13 at 12:47 AM Reply With Quote
What model rack?
Grimsdale
posted on 9/1/13 at 09:04 AM Reply With Quote
I'm halfway doing this on a sierra rack. Bought a new rack, which i managed to strip last night, going for the rebuild tonight.
What bit are you stuck on? getting the old pinion out?
The Venom Project
posted on 9/1/13 at 09:57 AM Reply With Quote
It's a Sierra Manual rack
I bought a second rack, its dreadful, all corroded and rusty, left Plus Gas working its way into the thread overnight, will see tonight on that one.
Was not able to release the track rod end whilst the steering rod was in the vice, it just twisted out of the vice. Also couldn't release the tie rod from the rack.
I still have my original rack fitted on my Trike, but couldn't get the slipper plug cover out, so all in all, I have 2 unworkable racks. But at least the rack fitted works but is not a quick steer, will it make much difference? Is it really worth the hassle to fit the Quick Rack bits?
I am loathed to buy a third rack, nobody I have spoken to this morning actually recondition's racks, they sell them, but don't do them.
Just been told by Ford in Huddersfield that the spares kit which includes the bearing on the spline, both covers etc is no longer available, so I guess I will resign myself to the fact that it isn't going to get fitted and just keep the rack on.
I think I will just sell the quick rack internals now
Grimsdale
posted on 9/1/13 at 10:13 AM Reply With Quote
i would recommend a quick rack if you're intending any spirited driving, means you can react quicker to any oversteer, without taking your hands off the wheel.
I may be help you out, i'll let you know once i've rebuilt and tested mine
However, you should be able to remove the track rod by turning the rack all of the way left, exposing the rack teeth, and clamping that in the vice. Then use stilsons/large mole grips to remove the rod.
For £35 i bought a new rack to dismantle, which gives me a spare pair of track rods, gaiters and pinion bearing. Reasonable value, and less likely to be seized.
[Edited on 9/1/13 by Grimsdale]
