Kevin
| posted on 9/1/13 at 06:35 PM |
Sierra Hazard Wiring
I have wired Sierra hazard warning switch on top of steering column and all is flashing ok. I believe that it should light up when side lights are on.
Can someone help with a simple diagram or explain how this is done. Thanks
AndyW
| posted on 9/1/13 at 06:42 PM |
mine does not light up unless the hazards are on. Then it just flashes.
big_wasa
| posted on 9/1/13 at 06:54 PM |
^^ what he said ^^
Kevin
| posted on 9/1/13 at 06:58 PM |
Thanks but I thought that it had to be luminated when lights are on for IVA
Davg
| posted on 9/1/13 at 08:31 PM |
Nope you will be fine as is.
Kevin
| posted on 10/1/13 at 05:46 AM |
theduck
| posted on 10/1/13 at 09:39 AM |
IVA manual does say it needs to illuminate with lights on though? Is it ok as it is from the donor andnon the donor it doesn't illumnate or does
whatever switch you use not have to illuminate?
