Author: Subject: Gluing aluminium to GRP??
Sloan85
posted on 20/1/13 at 12:20 AM Reply With Quote
What's the best adhesive to fix aluminium to GRP? I need to fix some brackets to the back of the dash and don't want to drill holes through it.
Cheers!
computid
posted on 20/1/13 at 12:39 AM Reply With Quote
Personally I would glass them on. You can pickup a fibreglass kit in halfords for a tenner.
ReMan
posted on 20/1/13 at 01:06 AM Reply With Quote
PU adhésive, surfaces keyed and grease free
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 20/1/13 at 08:53 AM Reply With Quote
Sikaflex
Thurbs
posted on 20/1/13 at 10:36 AM Reply With Quote
Tigerseal will stick poo to a blanket !!
deezee
posted on 20/1/13 at 10:57 AM Reply With Quote
Do you often need to stick poo to a blanket? You have some weird hobbies!
Thurbs
posted on 20/1/13 at 02:04 PM Reply With Quote
Just a saying mate, thanks for your recommendations just another wise arse with nothing else to do !!!
HowardB
posted on 20/1/13 at 03:06 PM Reply With Quote
we used to use araldite 3000 and something at british aerospace, it would tear the aluminium before breaking the bond,. however I expect that is a little extreme. The other excellent suggestion is 3M VHB tape, it is amazing stuff,...
hth
Howard
deezee
posted on 20/1/13 at 04:12 PM Reply With Quote
Whoa, calm down pal It was just some tongue in cheek humour because the actual saying is "will stick LIKE poo to a blanket". Do you see? one is a reference to how sticky poo is, your reference is how well you can glue poo to linen?
I'm sorry that the joke didn't come across very well, but frankly having seen how you react, I'll try to keep out of your way in the future. Bit too serious for my liking.
RK
posted on 23/1/13 at 01:26 AM Reply With Quote
Ah, don't listen, winter brings out the worst in everyone. I think what we call JB Weld would work, but Sikaflex on a keyed surface should be OK. Fibreglassing onto ally is a dangerous thing, but maybe when keyed would be good. Tends not to want to stick, which is why using ally moulds works so well when fibreglassing.
