Stott
| posted on 25/1/13 at 05:26 PM |
V5 - Keepers / Dates question - help please
Hi all,
Just received my V5 for the Robin Hood which was given an age related newly made up D plate
It has the number of former keepers as 5, with the previous registered owner showing as that of the donor vehicle.
It has "rebuilt - assembled from parts some or all of which were not new" in the special notes section
It has the date of me aquiring the vehicle as 06/02/1997 (which is about when I bought the donor)
It has date of first reg as 01/08/1986 EDIT: also date of first reg in uk 01/08/1986
Is this all correct? To the uninformed it looks like I own a Robin Hood which was registered in Aug 86, that has had 6 owners including me, and
I've owned it for 16 years ish. I thought it would be a bit clearer than this with at least some reference to the date the RH was
built.
Help/advice appreciated,
ta
Stott
[Edited on 25/1/13 by Stott]
Ben_Copeland
| posted on 25/1/13 at 06:31 PM |
Most of that is wrong. If its just been iva'd then it should have only one owner. The acquired date is wrong and several other bits I believe.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
snapper
| posted on 25/1/13 at 07:16 PM |
My Robin Hood V5 states first registered as month after SVA
No former keepers
Made from parts not new
I eat to survive
I drink to forget
Ben_Copeland
| posted on 25/1/13 at 07:28 PM |
Get it changed quick... Put the corrections on the V5, sign it and send it back. Dont bother ringing them, they are next to useless
Ben
Roadster
black fingernail
| posted on 25/1/13 at 07:56 PM |
Be sure to post it to be signed for, they have a habit of losing things then saying they have'nt recieved it.
robinj66
| posted on 25/1/13 at 07:57 PM |
If you are going t return it don't forget to take a copy.
I had a similar problem with the date of first registration - set it all out in a comprehensive letter - DVLA said they were correct.
As said above, this is plainly B****cks but good luck with persuading the DVLA that they don't know what they're doing
johnemms
| posted on 25/1/13 at 08:30 PM |
If you keep the body (ie:escort) and put all new zetec gear in - it retains reg & tax etc..
If you scrap the body - new chassis but keep all original running gear - new reg - new tax class - new book.
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
Stott
| posted on 25/1/13 at 08:57 PM |
Yeah all your replies are as I expected.
I wanted a V5 saying first reg'd 12/12/12, built from bits that might not be new, 0 previous keepers type-of-thing,
So what's the concensus, write the corrections on the V5 and send it back (recorded and having taken a copy)? Or do I put it all in a letter and
attach it to the V5 and send?
To make it even worse they got my address wrong too, 0/10
chillis
| posted on 25/1/13 at 09:35 PM |
Get the V5 corrected now how ever painful it might be, as down the road could cause more hassle as it might appear to have been rung from another
older Robin Hood.
Never under estimate the ingenuity of an idiot!
Stott
| posted on 28/1/13 at 12:55 PM |
Bump!
Do I just write corrections all over the v5 and sign and return it as suggested or do I go about it some other way?
Stott
Davg
| posted on 28/1/13 at 02:16 PM |
Hi Stott if you can, take things back to local office where u applied to register the car and bite thy lip and explain nicely! Worked for me a while
ago with aprevious build. If you have to send it I would write an explanatory letter and not all over the document.
Cheers D
