Author: Subject: Alternator direction
jon200
posted on 30/1/13 at 10:22 AM Reply With Quote
How do you know what direction your alternator is designed to run? I need to find a replacement smaller one but i am not sure the OE direction. Is it looking at the front of the engine crank pulley or from the rear of the alternator?
What size can i go down to Amps wise for a 2L turbo?
adithorp
posted on 30/1/13 at 10:30 AM Reply With Quote
Alternators run clockwise when viewed from the front same as most engines (with the exception of a few Honda's).
http://jpsc.org.uk/forum/
plentywahalla
posted on 30/1/13 at 10:33 AM Reply With Quote
I am fairly sure that they can run in either direction. The fan may not work so well though.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
r1_pete
posted on 30/1/13 at 11:58 AM Reply With Quote
They can, and yes the fan needs changing.
Straight 6 E Types with Aircon had the alternator mounted the opposite way, pulley facing the driver, to fit the air con pump in.
mcerd1
posted on 30/1/13 at 01:12 PM Reply With Quote
what else are you running off it ?
headed windows, geat big spot lights, electric windows, etc.... - or a track car no lights at and it just needs to start the engine
posted on 30/1/13 at 01:36 PM Reply With Quote
Fuel injection system takes a fair current but by modern tin top standards you don't need a big alternator 40 amps is more than enough. If you have carbs you can go even smaller.
jon200
posted on 30/1/13 at 05:10 PM Reply With Quote
It's just starting and lights I'd need it for. Are there any the people use because they are small?
r1_pete
posted on 30/1/13 at 06:44 PM Reply With Quote
Nippon Denso from a Diahatsu Charade is a popular choice, sorry I never did establish the model number, but its running fine on my E Type.
mini alternator
mini alternator
40inches
posted on 30/1/13 at 06:45 PM Reply With Quote
A lot use A073 Daihatsu Denso Kit Car Lightweight Alternator | eBay
jon200
posted on 31/1/13 at 06:40 PM Reply With Quote
That's pretty small! Will have a look out for a cheap one on eBay, have seen one but its from a terrios. Not sure if its the right one.
http://item.mobileweb.ebay.co.uk/viewitem?itemId=300851857134&kw=300851857134
[Edited on 31/1/13 by jon200]
