Author: Subject: Exhaust manifold lenghtening!
cps13
posted on 4/2/13 at 01:20 PM Reply With Quote
I have recently bought a westy exhaust manifold off a member here, got the advice that they will fit an MK indy chassis. Which i'm sure they will if the clever ones on here say so! But my chassis is a mix'n'match of westy and mk indy (westy rear and mk indy front). I bought it off someone a couple of years back and understand why they sold it, it as a oversized pain in the ass!!
Anyway, back to the original point... the manifold will not fit in my car, the underside of the pipe touch against the chassis when the engine is in place. if they were further out by about 3-5mm it would clear, only marginal difference.
Could I extend the pipes? Either by by getting a thicker plate welded on which bolts to the block or another method? Or is it simply a case that my pipe is too small?!
Also, do you need a certain amount of clearance from the side panels so that they don't melt?
T66
posted on 4/2/13 at 01:46 PM Reply With Quote
Post a picture, probably easier to see whats up.
will121
posted on 4/2/13 at 05:45 PM Reply With Quote
Not 100% sure of you exact problem but could you space it off the head with a dummy flange plate and additional gasket if manifold studs are long enough like this?
[Edited on 4/2/13 by will121]
cps13
posted on 4/2/13 at 06:27 PM Reply With Quote
I have attached a crude diagram on this link
http://bakinggoodcakes.co.uk/Untitled.jpg
If I were to put a dummy flange would I simply sandwich it between two gaskets?
will121
posted on 4/2/13 at 06:36 PM Reply With Quote
Yes mine is just a home made spacer cut out of a 6mm piece of Ali with gasket to both sides
cps13
posted on 4/2/13 at 06:46 PM Reply With Quote
thanks - will order some. I am not going to get to the car for about 2 weeks now can you remember a rough width of the flange by chance?
will121
posted on 4/2/13 at 08:34 PM Reply With Quote
mine is a 1600 CVH what engine are you talking about? may be you could buy the second manifold gasket and use as a pattern, but may be better to use the spacer to match any differance between head ports and manifold flange
T66
posted on 4/2/13 at 09:06 PM Reply With Quote
Isnt there someone on here who will water cut flanges ?
Paul Turner
posted on 5/2/13 at 09:53 AM Reply With Quote
Plenty of places offer manifold flanges for DIY'ers. Heres one.
http://www.danstengineering.co.uk/Flange%20Shop.htm
MarcV
posted on 5/2/13 at 10:52 AM Reply With Quote
I would allow for a little more clearance. If it just clears by a mm it will surely touch from time to time due to engine movement?
