<<  1    2  >>
Author: Subject: Physically Smallest Diff
posted on 5/2/13 at 01:51 PM Reply With Quote
I'm fannying about with a V-twin engine just now and would like to couple the drive-flange directly to a differential.
My space is restricted, so I'm looking for a diff that's particularly short in length.
Does anyone have any suggestions, or can offer any length dimensions of certain units?
Ta muchly!
It's Evolution Baby!
mcerd1
posted on 5/2/13 at 02:18 PM Reply With Quote
I'm sure there are smaller ones, but you welcome to borrow/measure up one of my sierra diffs (7" )
[Edited on 5/2/2013 by mcerd1]
posted on 5/2/13 at 02:45 PM Reply With Quote
Quad bike diff perhaps, no idea of cost/strength/ratios etc, but they must be pretty compact.
Failing that what about a Honda CRV or something similar.
40inches
posted on 5/2/13 at 02:57 PM Reply With Quote
Front diff from a Sierra 4x4?
MK9R
posted on 5/2/13 at 03:41 PM Reply With Quote
The free lander is shorter than a Sierra
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
adithorp
posted on 5/2/13 at 04:01 PM Reply With Quote
I had a look into connecting engine direct to diff a while ago. The problem is the two have to be perfectly aligned. Any mis-alignment or flex between the two can result in failure of one or both.
http://jpsc.org.uk/forum/
bashracing
posted on 5/2/13 at 04:56 PM Reply With Quote
1.6 mx5 6'' diff is fairly short
me!
posted on 5/2/13 at 05:01 PM Reply With Quote
The Fiat Panda 4x4 uses a pretty small rear diff- but good luck finding one!
Maybe some of the other very small 4x4's would be some use, Subaru Justy, Diahatsu Charade etc?
posted on 5/2/13 at 05:07 PM Reply With Quote
Cheers guys. Will look into some of the suggestions.
posted on 5/2/13 at 05:08 PM Reply With Quote
Maybe put a single UJ between them?
bashracing
posted on 5/2/13 at 05:18 PM Reply With Quote
or try these lot for a small rubber doughnut coupler
http://www.fptgroup.com/distfinder/dist_results_uk.asp
posted on 5/2/13 at 05:29 PM Reply With Quote
Ooh... the Honda quad diffs are very neat, but I guess they wouldn't like 80ft/lbs, 10k rpm limit and 600kg vehicle weight!
Cheers... will look into it.
matt_gsxr
posted on 5/2/13 at 06:20 PM Reply With Quote
What about one of these beauties?
http://www.transworks.biz/minidiff.html
big_wasa
posted on 5/2/13 at 06:44 PM Reply With Quote
the mondeo/jag 4x4 maybeworth a look.
bashracing
posted on 5/2/13 at 06:56 PM Reply With Quote
hoooooooowwwwww muuuuuuuuuuuuuuuuuuucccccchhhhhhhhhh???????????????
JC
Might be a hens teeth suggestion, but Suzuki Cappucino? It's gotta be small!
ETA at least 2 on the 'bay
Suzuki Cappuccino Rear Diff Differential 660cc 1994 Warranty | eBay
[Edited on 5/2/13 by JC]
posted on 5/2/13 at 07:04 PM Reply With Quote
£1200???
That's pretty cheap considering it's your diff, has a reverse and also the brake calipers / discs.
An reverse diff from Elite is almost twice the price!
posted on 5/2/13 at 07:06 PM Reply With Quote
Found one!
posted on 5/2/13 at 07:08 PM Reply With Quote
Ah... just spied the brake kit is an extra $650.
posted on 5/2/13 at 07:31 PM Reply With Quote
Yup... that's quite squat. I wonder if the input shaft could be shortened a bit?
Andy S
posted on 5/2/13 at 08:19 PM Reply With Quote
Triumph Spifire
minitici
posted on 5/2/13 at 08:43 PM Reply With Quote
Ta muchly!
Scott, Which end of the vehicle are you fitting the differential?
Is it for the front of a reverse trike?
Or are you trying to drive a single rear wheel of a reverse trike?
As others have said a Freelander rear differential is fairly compact and has a light alloy case.
posted on 5/2/13 at 09:14 PM Reply With Quote
Hi Doug,
It's for a Smart Roadster with an Aprilia V-twin mounted transversely.
PS - I've been looking at some of the bigger ATV's (400+kg's) and it seems that plenty of them have LSD's and a fair bit of torque. The likes of this Can-Am diff has Visco-Lok...
2013 Outlander 1000 XMR Front Differential Diff Assembly Canam Can Am 705401077 | eBay
minitici
posted on 6/2/13 at 11:43 AM Reply With Quote
Scott,
You could always fit a sprocket to the input flange of a differential and link to the engine via a short chain.
<<  1    2  >>
