New Topic New Reply
Author: Subject: Seat and Box Mounts
Padstar
posted on 3/3/13 at 02:14 PM Reply With Quote
Seat and Box Mounts
2 quick questions if i may. I cant see any plates specified in the book for the seat mounting brackets? i have been through it a few times now but cant locate. I see from pictures that there seems to require a flat plate run from tran tunnel to outerside of chassis.
What thickness plate should be used and at what dimensions should they be mounted from the rear of the cockpit? Do you need to up the plate if i were to perhaps be of slightly heavier build
Also are the gearbox mounts shown in the book ok to use for a Mk1 MX5 transmition?
New Topic New Reply
