Author: Subject: Need advice finding some injectors.
r1_pete
posted on 18/3/13 at 01:46 PM Reply With Quote
I'm still working on and EFI setup for the 4.2L 6 cyl Jaguar, stock BHP is claimed as 265, so I think I need injectors in the 280 - 350 cc/Min range.
Can anyone reccomend a source of common, ok cheap, injectors, I was thinking about Subaru WRX or similar, any advice welcomed.
andylancaster3000
posted on 18/3/13 at 02:52 PM Reply With Quote
I have used these on the duretec:
Bosch 0280155766, 347cc @3Bar, high impedance, EV1 connectors. Usual stuff that you're most likely to want.
As used on volvo T5 among others. I got a recon'd+tested set for £90 from ebay.
Where do yours sit in the inlet tract?
[Edited on 18/3/13 by andylancaster3000]
40inches
posted on 18/3/13 at 03:04 PM Reply With Quote
I know someone with a full set of 4.2, new, Bosch injectors, a full set of 3.6, used, and a Jag 6 fuel rail with clips.
You could probably prise them off him for £80 the lot.
r1_pete
posted on 18/3/13 at 05:33 PM Reply With Quote
Thanks, they sit in the manifold like this:
Injectors2
Injectors2
Here is the back of the manifold, as you can see they point directly into the port
I have 4.0L X300 injectors at the moment, but they are only rated at 220cc, My logic (probably flawed) when buying them was that the modern 4.0L straight 6 was bound to produce more BHP than a 45 year old 4.2 six.
loony
posted on 18/3/13 at 07:29 PM Reply With Quote
I was using Saab "red" injectors in my BMW 325i Turbo project... They are about 359cc/min@2.5 bar.
Bosch number 0 280 150 431....
The problem is that they came from 4 cylinder car, so you need 1,5 sets Or seler who will sell you just six of them...
Lucas
CNHSS1
posted on 18/3/13 at 09:52 PM Reply With Quote
std nissan s13 200SX (pop up headlight model) are 370cc and sell used for 15-30 quid for 4.
std skyline injectors are 440cc and are circa 80-100 quid a set of 6.
check out driftworks or sxoc forums
