Author: Subject: Exhaust routing
Chaddy
posted on 18/3/13 at 02:55 PM Reply With Quote
Exhaust routing
Hi All
For IVA will it be ok to route my exhaust between the rear wishbones so long as it can not come into contact with anything through the full movement of the suspension.
Chaddy
Tiger Super Six
posted on 18/3/13 at 04:03 PM Reply With Quote
Isn't there a drive shaft going through there as well? Surely there's not enough room?
Mark
Tiger Avon
Chaddy
posted on 18/3/13 at 04:10 PM Reply With Quote
It should sit behind the drive shaft, so as to come from the back of the car to the front.
Slimy38
posted on 18/3/13 at 04:39 PM Reply With Quote
Behind the driveshaft? I'm not sure what you mean? I'd expect the exhaust to go above or below the driveshaft as it passes through the wishbones.
How close to the wheel will it be if it's going between the wishbones?
Chaddy
posted on 18/3/13 at 04:56 PM Reply With Quote
Hard to explain, it doesn't go through front to back it threads through top to side.
Daddylonglegs
posted on 18/3/13 at 05:02 PM Reply With Quote
Drawings/pictures might help chap?
loggyboy
posted on 18/3/13 at 05:10 PM Reply With Quote
To be fair, theres no need to know hes going to do it, the simple answer is, as the OP suggested, as long as nothing can come in to contact with any moving parts, and heat isnt likely to effect brake & fuel lines then you should be fine for IVA.
[Edited on 18-3-13 by loggyboy]
Mistral Motorsport
eddie99
posted on 18/3/13 at 05:15 PM Reply With Quote
Cant see why it wouldnt be ok. I have seen some cars with the exhaust where you mention.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Chaddy
posted on 19/3/13 at 09:20 AM Reply With Quote
Thanks all, I'll post some pics when it is done.
