Author: Subject: X Flow Valve Springs
Nickctp
posted on 18/3/13 at 08:32 PM Reply With Quote
Evening all,
I have been advised that the standard valve springs are not any good for an upgraded cam such as the BCF2 on a Ford cross flow 1600 head. I was told they should be double valve springs or at least a stronger spring than the standard?
Can anyone shed any light on weather this is just an advisory or an essential?
Nick
skodaman
posted on 18/3/13 at 08:46 PM Reply With Quote
Check Burtons catalogue. I think they do a stronger single valve spring for BCF2 cam.
Skodaman
phil m
posted on 18/3/13 at 08:49 PM Reply With Quote
Hi
If you buy a new kit it should come with the required springs/doubles
steve m
posted on 18/3/13 at 08:51 PM Reply With Quote
personly, i run standard springs on a 270 cam, but keep the max revs to 7k
any more than 7k and the valves /springs bounce even with double coils, plus the power output up at 7k, is lower than 6.5k, so why bother ?
posted on 18/3/13 at 09:21 PM Reply With Quote
The springs in my BCF2 kit were singles , engine occasionally revs to 7,000rpm .As said have a look at the Burtons catalogue
