Author: Subject: Steering rack Help!!
chrisf
posted on 30/9/04 at 03:27 PM Reply With Quote
I need to take apart my steering rack. I'm pretty sure it is a MKII. (It came from a Westfield.) There is a large female bolt on the top of the rack. What size is it? Also, what is the thread size/diameter at the end of the rack?
--Thanks, Chris
Bob C
posted on 1/10/04 at 11:55 AM Reply With Quote
Hi Chris,
the escort racks I've seen don't have the "large female bolt" (is that one that doesn't have any nuts?) - the preload is set with shims.
ATB Bob
Matthew_1
posted on 1/10/04 at 12:51 PM Reply With Quote
I've had two ford racks and the tie rods are either M14 or 1/2" UNF.
chrisf
posted on 1/10/04 at 01:05 PM Reply With Quote
Hi
My rack looks exactly like this.
If you look at the top, you can see the indention where the female bolt goes. I actually figured out how to remove it last night, but did not have a good look inside (needed to clean the workspace).
Thanks for the thread size. Mine is bigger than 1/2", so I'll try an M14 nut before I order any rod ends.
I'm curious now the steering rack I have. Anyone know the length of their steering rack from end to end?
--Thanks all, Chris
[Edited on 1/10/04 by chrisf]
chrisf
posted on 29/10/04 at 01:32 PM Reply With Quote
I'm now in a bit of a bind. I need to order my steering extensions from the machine shop. I told them I needed M14 on the steering rack side. They asked what pitch I needed. I told them it was course. I assumed there were two options: fine and course. Does anyone know what pitch I need? Is it 2.0?
I'm a bit new to the metric fastner world.
--Thanks! Chris
pbura
posted on 29/10/04 at 03:30 PM Reply With Quote
2.0mm pitch would be coarse and 1.5mm is fine. You can measure the pitch (distance between crests of the threads) yourself with a metric rule.
If you own one, that is! Where the hell is mine?
Pete
Pete
type 907
posted on 29/10/04 at 06:33 PM Reply With Quote
Hi Chris
Mk 2 Escort rack is 14 x 2
I made my own. Is this piccy any help?
Too much is just enough
