Author: Subject: Exterior radius
40inches
posted on 22/3/13 at 04:41 PM Reply With Quote
Exterior radius
Can anyone who has had an IVA recently confirm that these radii are checked. Ta.
renetom
posted on 22/3/13 at 05:18 PM Reply With Quote
Hi
Ours were ok on our indy
but he did not bother to check them
Dec 11
Good luck
René
40inches
posted on 22/3/13 at 05:31 PM Reply With Quote
Originally posted by renetom
Hi
Dec 11
Good luck
René
Thanks, trying to dot the i's and cross the t's
renetom
posted on 22/3/13 at 05:46 PM Reply With Quote
Have you got trim around the edges
& holes where the seat belts go through
on you seats ? can't see on the picts.
Interior trim
Interior trim
Andy S
posted on 22/3/13 at 05:49 PM Reply With Quote
Sorry for the thread hijack but is that wheel pad on the Mountney purchased or home made?
renetom
posted on 22/3/13 at 05:54 PM Reply With Quote
Came with it , but can't remember from where .
40inches
posted on 22/3/13 at 07:07 PM Reply With Quote
Interior trim
Interior trim
No, but yes Sent the forms out today, so going through a (long) list of IVA related topics.
On the subject of self centering, what did you do? I know I could do a search, but that brings up a lot of, sometimes,
contradictory advise. So I would appreciate advise from someone who has just gone through IVA with an Indy
pekwah1
posted on 22/3/13 at 07:57 PM Reply With Quote
out of interest what is that steering wheel?
ReMan
posted on 22/3/13 at 08:09 PM Reply With Quote
ISTR this is out of scope as something to do with the floor line
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
40inches
posted on 22/3/13 at 08:43 PM Reply With Quote
I must check the manual more closely, I thought they had rescinded the floor line exclusion
Nice colour scheme Mr ReMan, shows a person with impeccable taste
Just checked:
"The assessment will not apply to exterior mirrors"
"Note the floor line its self is subject to the requirements of RS2 i.e. the 2.5mm radius requirement applies."
Oh well! Out with the file.
Interesting that exterior mirrors are exempt.
[Edited on 22-3-13 by 40inches]
Jimfin
posted on 22/3/13 at 09:00 PM Reply With Quote
Not the question you asked but are - the reverse and fog lights high enough (250mm min)?
40inches
posted on 22/3/13 at 09:04 PM Reply With Quote
260mm, with the rear jacked right up
All questions or observation's welcome
ReMan
posted on 22/3/13 at 09:29 PM Reply With Quote
Just checked:
Colour scheme?, yes, its the only one befitting of such a vehicle
Radius, thats a bummer.
Could use some self adhesive pac-man profile rubber?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
L5W
posted on 22/3/13 at 10:08 PM Reply With Quote
Hi, my Indy was IVA'd 2012 and the side panel radii were definitely checked at the Norwich VOSA station, i cant remember if they checked the back panel underside though. I purchased the kit in 2009 and I think MK has adjusted the radii along the underside of these panels once the test changed from SVA to IVA. I bought a cheap radius checker tool from ebay just to make sure anyway.
I kept a close eye on Dunk3's build pics during my build and he used some ally hockey trim to increase the radii along these panels (I'm fairly sure he had the older/SVA MK bodywork but I might be wrong)
Lee
http://l5w-mk-indy-zetec.blogspot.com/
ReMan
posted on 22/3/13 at 10:16 PM Reply With Quote
" think MK has adjusted the radii along the underside of these panels once the test changed from SVA to IVA."
That would impress me!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
L5W
posted on 22/3/13 at 10:26 PM Reply With Quote
yeh I wasn't sure at the time so called them and they said "it'll be ok". Given my previous experience with them, I wasn't 100% convinced it actually would be ok so decided to check it myself with the radius tool I bought and it was over 2.5mm. Assumed they must have changed it at some point since dunk used the extra ally trim along the under side of his build to increase the radius in this area
Lee
snapper
posted on 23/3/13 at 05:27 AM Reply With Quote
Self centering is affected by caster/KPI
For the test high front tyre pressure (30psi) and some toe out helps on any car
I eat to survive
I drink to forget
renetom
posted on 23/3/13 at 07:48 AM Reply With Quote
We just did as snapper said & it scrapped through
After the test got some rose jointed wishbones from MK
This enabled us to get 7.5-8 degrees of castor angle
This improved the self centring , but not as good as a tin top.
Stainless washers as crush tubes
renetom
posted on 23/3/13 at 07:51 AM Reply With Quote
Mountney
40inches
posted on 23/3/13 at 10:45 AM Reply With Quote
Lee
My kit is circa 1999, and the chassis is a Locost/Indy hybrid, the side panels are very square on the bottom
40inches
posted on 23/3/13 at 10:54 AM Reply With Quote
Thanks for that snapper, I had a DOH! moment after spending a day making up a string box, and setting the geometry
Out with the string box again then!
