Author: Subject: X flow heavy duty valve springs
Nickctp
posted on 30/3/13 at 03:33 PM Reply With Quote
Hi all,
I'm after a set of heavy duty valve springs & retainers for a 1600 xFlow. Any one able to help?
Nick
myke pocock
posted on 30/3/13 at 06:43 PM Reply With Quote
Burton Engineering?
Nickctp
posted on 30/3/13 at 07:20 PM Reply With Quote
Originally posted by myke pocock
Burton Engineering?
I just wondered if anyone happened to have a spare set!! Burtons are so dear now for spares
teegray19
posted on 30/3/13 at 09:10 PM Reply With Quote
Ive got a set not being used. Brand new never fitted. £45? Single springs but uprated... piper springs range
teegray19
posted on 30/3/13 at 09:14 PM Reply With Quote
http://www.pipercams.co.uk/pipercams/www/product_nav.php?type=C&cat=VS&man=8&engine=246
Bottom single springs
Westy1994
posted on 30/3/13 at 10:22 PM Reply With Quote
Does the cam you have chosen, give its peak power in RPM beyond that of the capability of the standard springs, I assume it does given you have posted , but just be aware that this will increase valve train loadings, are your posts now strong enough for example.
Nickctp
posted on 30/3/13 at 10:40 PM Reply With Quote
Thanks teegray,
I will find out if they are suitable and let you know! Do you have the retainers?
Nick
Nickctp
posted on 30/3/13 at 10:44 PM Reply With Quote
I believe not. It's the (Kent BCF2) but have been advised the springs should be changed for at least the heavy duty ones. With this cam - everything else should be fine and not need uprating. Just being cautious I presume.
Westy1994
posted on 30/3/13 at 10:54 PM Reply With Quote
That's cool, just didn't wish to see you waste cash on something you may not need, all springs get softer the older they are when in use, again something to be aware of.
teegray19
posted on 31/3/13 at 08:44 AM Reply With Quote
Nick they use standard retajners, you may need to machine some of the valve seats to get the correct crush length. I didnt have to but depends what someome else has done to the head. Check specs on piper first. I can post out on tuesday if you like.
