Author: Subject: Fury at Bonneville
Chet
posted on 6/4/13 at 09:38 AM Reply With Quote
Fury at Bonneville
A well known Bonneville class record holder is interested in using a Hayabusa powered Fury to set some new records in 2013.
I have a real 235 HP, 1441 Busa with TTS OD gears built by Bob Carpenter ( USA Busa Expert ) for the engine.
We are now looking at a custom quick change diff.
Can anyone tell me the fastest known top speed for a Fury?
Chet
jeffw
posted on 6/4/13 at 09:51 AM Reply With Quote
I would guess and say Ruari's cossie engined car was the fastest Fury. Over 150mph I think.
clairetoo
posted on 6/4/13 at 09:56 AM Reply With Quote
I think it ran over 170 at Brintingthorpe........
My V6 went over 155 , but prop vibration stopped it going completely flat out !
Its cuz I is blond , innit
Claire xx
Will weld for food......
Chet
posted on 6/4/13 at 12:55 PM Reply With Quote
Hi Claire,
Can you please share your experience with the Fury's handling at very high speed?
Does your car have any aero additions?
Car weight / balance / rake ?
Any suggestions to improve performance would be very helpful.
Chet
[Edited on 6/4/13 by Chet]
omega0684
posted on 6/4/13 at 04:25 PM Reply With Quote
Originally posted by Chet
Hi Claire,
Hi Chet,
You obvious you don't know Claire, otherwise you would have never asked her this question Are you sure you're prepared for the answer!
its an experience in itself being a passenger in claires fury! (I will say no more! )
All the best
Chet
posted on 6/4/13 at 05:27 PM Reply With Quote
I'm willing to risk the question to Claire because
1. To the best of my knowledge only a few people have been over 150 mph in a Fury ( soon to change though - LOL ) &
2. I'm safe here in the USA
Chet
JonnyS
posted on 6/4/13 at 06:17 PM Reply With Quote
You can see the above mentioned car here:
https://www.youtube.com/watch?v=_dmvPHeOyV8
On the straights it's doing over 140 rock solid without even trying.
daniel mason
posted on 6/4/13 at 06:25 PM Reply With Quote
that cars for sale i think!
adithorp
posted on 6/4/13 at 06:32 PM Reply With Quote
I've never maxed mine out but I've been to 140 and still accelerating a couple of times (gearing should take it to just under 150 @ rev limit). It starts to feel a bit (lot) light on the steering but stable. The back edge of the bonnet lifts a bit with the air pressure under it.
Running an 06 R1 though a Freelander diff'. 550kg split F49/R51% Aero wise... a full floor, rear diffuser and a couple of corner splitters on the front arches. The splitters did make it feel more planted at high speed and in long fast corners (all subjective though).
http://jpsc.org.uk/forum/
daniel mason
posted on 6/4/13 at 07:42 PM Reply With Quote
im just waiting to max mine out! im also on a freelander diff with quaife atb, but a bit less power with the blade motor.
it is however a 50mm lowered race cahassis, and is circa 430kg
clairetoo
posted on 6/4/13 at 08:37 PM Reply With Quote
Hi Claire,
Chet
I have never noticed any problems at speed - way back when it was crossflow powered it maxed out around 145 and was stable , the only `airo' on the car could be the bonnet bulge (which seems to push light rain over the screen , only showing small patches of rain on the top corners)
Balance-wise , it is within 5kgs front/rear (but heavy at 680 kgs) , I have never checked rake - it just looks right to me !
Alex - I'll have to take you for a spin in the V6 Mx5..........it a hoot
Claire xx
adithorp
posted on 6/4/13 at 09:19 PM Reply With Quote
Whats the record/class he wants to go for?
franky
posted on 6/4/13 at 09:30 PM Reply With Quote
surely a fury should go much faster than 150+mph if a brick 7 clone and do 155+?
Chet
posted on 7/4/13 at 01:33 AM Reply With Quote
FYI
Current Bonneville Records
Unblown Gas Modified Sports = GMS/
Engine size = 1.01 to 1.5 = H
Current record = 165.444 mph
Engine size = .76 to 1.0 = I
Current record = 150.181 mph
The I class record looks interesting.
Chet
[Edited on 7/4/13 by Chet]
jeffw
posted on 7/4/13 at 06:11 AM Reply With Quote
My Phoenix did 163 at Spa (geared for 170) according to the GPS datalogger....but it isn't a Fury lol.
Chet
posted on 7/4/13 at 03:18 PM Reply With Quote
Bonneville requires a production minimum of 500 cars for these classes.
How many Phoenix have been formally sold?
Jeff-
What powertrain setup did you use at Spa to do 163?
Chet
