Boltsy
posted on 9/4/13 at 08:39 PM |
ARB advice needed
Can someone inpart their advice please......I have rebuilt my Westfield Megablade over the winter ready for the new race season in RGB. In setting up
the ride height and corner weighting, i discovered the old shocks & springs were u/s so a new set of Pro comp double adjustable shocks were
installed on 250lb springs (all round).
When i went to install the fronts, the shock tops foweled the Westfield Anti Roll bar set up so it was removed with a view to replacing it later with
a more bespoke arrangement.
Having done a fair bit of research now, i have managed to get totally confused as to weather or not i actually need an anti roll bar at all, as the
consensus seems to lean towards the fact that they are only used to "fine tune" roll & pitch of the car.
So i guess the question is a) should i replace the front ARB b) should i run with no ARB's front & rear c) leave the rear connected and no
front d0 just set the car up using the bump & rebound adjustments only (help there too please!)
Really confused..HEEEELLLLLPPPPPP!
Limitation starts where the visions end - Jimmy Johnson
procomp
posted on 9/4/13 at 11:19 PM |
Hi.
Are you sure you have my dampers on. I would not have suplied 250lb springs.
If you want to give me a call in the workshop ill give you some ideas re roll bars. for example i do 9 different strength bars for the front end.
Cheers matt
Boltsy
posted on 10/4/13 at 07:48 PM |
Hi Matt,
Purchased through Andy at AB...They are the ones you had to supply the 1" longer top mounts for about a month ago. What can you offer for the
front end as Brands is looming up fast. Was going to make one from scratch but can't get any 1/2" Dia. EN47 Bar. Seems to be like rocking
horse S**t or cost an arm & a leg.
Boltsy
posted on 10/4/13 at 07:49 PM |
BTW, Springs weren't from you!
procomp
posted on 10/4/13 at 08:19 PM |
Hi.
There is confusion some where as i havent suppled AB any dampers.
Re roll bars etc. just give me a call in workshop. 0121 3503258.
Cheers Matt.
Boltsy
posted on 11/4/13 at 05:45 AM |
Checked them out and they are Protech shocks....ooooops! I'll call you later on
