Author: Subject: Turbo Conversion Kits
Autoflock Motorsport
posted on 13/4/13 at 03:21 PM Reply With Quote
hello peeps,
ive been looking on the net for a turbo conversion for a k4 gsxy engine but to no avail. can anyone recommend a kit? My plan is to run a charge cooler with megasquirt sorting the technical stuff.
Any help would be great
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
imp paul
posted on 13/4/13 at 03:29 PM Reply With Quote
here you go just hope you like to spend lol before going to my link
http://www.holeshot-racing.co.uk/index.php/services/turbo-charging/13-suzuki/33-gsxr1000-k1gk4-turbo-stage-1-to-3
http://www.bigccracing.com/shop/product.asp?idproduct=328&source=thumb
both the above are the best people to help you and jack at holeshot is a topp bloke
[Edited on 13/4/13 by imp paul]
posted on 13/4/13 at 03:36 PM Reply With Quote
lol not even going to click on it, I did see thjat one off a quick google search, far to expensive imo
Im leaning towards going for a focus rs chargecooler, lower comp pistons and ms ecu, but im not sure about the turbo to use and also if i need to change things like valve springs, plugs etc. also not sure about turbo choice, making the cusom manifolds for the inlet and exhaust side isnt a problem, so it should be relativlyt cheap I think but this is new terratory for me so if im talking bollox please let me know
Kind regards
Raj
imp paul
posted on 13/4/13 at 03:43 PM Reply With Quote
no worrys yes you can build it your self. you could use a Mitsubishi td04 turbo ,and some je pistons, and ape valve springs and you will need to beef up the clutch lol
this should give you some help re parts you mite want .
Stage 1: GSXR1000 K1 to K4 7psi boost 240 RWHP / 1
20ft/lbs torque
Turbo Kit Parts
Mitsubishi turbo with integral wastegate and blow o
ff valve
700.00
Modified turbo to suit bike application
100.00
Headers
450.00
aluminium airbox plenum
260.00
brackets and fasteners
20.00
oil feed line and fittings to turbo
40.00
dash10 oil return line and fittings from turbo
80.00
air up pipe
100.00
Silicone joining pieces and jubilee clips
50.00
vacuum and fuel hoses and fittings
40.00
air filter
30.00
Parts Total
£1,870.00
Engine parts
heavy duty clutch spring kit with spacers and bolts
30.00
spacer head gasket and suzuki cover gaskets and oil
filter
90.00
adjustable cam sprockets
120.00
Parts Total
£240.00
Fueling Parts
480cc injectors, spacers, clips, and connectors
260.00
Fuel pump
140.00
Adjustable Fuel regulator and fittings
100.00
Parts Total
£500.00
Electrical / Engine management Options
Option1:- Piggyback fuelling option
powercommander 3usb
250.00
Dynojet universal hub (allows fuel map against thro
ttle and boost)
120.00
3bar map sensor and connectors
80.00
Parts Total
£450.00
