Author: Subject: Pictures of unusually engines in 7 wanted.
morcus
posted on 14/4/13 at 01:19 PM Reply With Quote
I'm still looking for a place to star building so I'm trying to research possible engine and 'box options and from what I'm told the best auto box option seems to come attached mostly to straight 6's in the form of BMW's and Jags. I know Speedy who used to be here had a xj40 engine in his and I've been watching some videos on youtube of a guy with a nissan 6. I tried googling for pictures but it didn't give me what I wanted so partly for inspiration, can any one post up pictures of engines that aren't the normal Ford 4 pots and bike engines, though feel free to post any way, I just want to see some pictures.
[Edited on 14/4/13 by morcus]
sdh2903
posted on 14/4/13 at 01:28 PM Reply With Quote
Have you looked at GKD? there standard car is for bmw 6 pots.
sdh2903
posted on 14/4/13 at 01:35 PM Reply With Quote
look here:
http://www.locostbuilders.co.uk/viewthread.php?tid=147123
morcus
posted on 14/4/13 at 01:37 PM Reply With Quote
Yes, I am considering a GKD Legend, I'm keeping all the options open. Looking at all thats available and also looking into finding a way to have a 4 pot, but I just really want some inspiration.
sdh2903
posted on 14/4/13 at 01:42 PM Reply With Quote
V8?
sdh2903
posted on 14/4/13 at 01:51 PM Reply With Quote
Dax
morcus
posted on 14/4/13 at 01:56 PM Reply With Quote
yeah, thats the stuff, thanks.
rodgling
posted on 14/4/13 at 04:22 PM Reply With Quote
Lots of GKD pics on my blog, http://crazydavesdeathtrap.blogspot.co.uk/
A guy in the Netherlands is building an SMG gearbox GKD:
http://www.vdvossen.nl/gkdlegend/wordpress
Not sure how far he's got with the SMG bits though.
[Edited on 14/4/13 by rodgling]
Volvorsport
posted on 14/4/13 at 04:34 PM Reply With Quote
search for benzine...
www.dbsmotorsport.co.uk
getting dirty under a bus
catman
posted on 14/4/13 at 04:44 PM Reply With Quote
what car is that V8 in? looks really neat with the in board suspension
Ed
caged supersix
Carbon/GRP
210 bhp silvertop
190 lbft
blakep82
posted on 14/4/13 at 04:47 PM Reply With Quote
Ive got a bmw 328 engine here needing a new home, £250 + courier, will even give the manual gearbox for free, but I know you want a auto
ALso got all the running gear, lsd, rear axle, bbs split rim wheels etc.. ;-)
________________________
fesycresy
posted on 14/4/13 at 04:53 PM Reply With Quote
On that V8 car, is there enough travel on the front rose joints?
They look like they are in the wrong orientation and would limit the range of motion.
ashg
posted on 14/4/13 at 05:30 PM Reply With Quote
longer the wishbone the less the inner rose joints move simples..... i suspect 50mm of travel at the wheel only amounts to 4-5mm movement on the inner rose joints
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
jacko
posted on 14/4/13 at 05:35 PM Reply With Quote
V8 car looks like a roadrunner build
Jacko
daniel mason
posted on 14/4/13 at 05:41 PM Reply With Quote
it is and the rose joints are correct this way. i thought the same a while back but was put in my place by the forum
the design and member placement however do not look good at all to me!
NeilP
posted on 14/4/13 at 07:15 PM Reply With Quote
The Luegos generally run slightly more exotic in terms of lump...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
SteveWallace
posted on 15/4/13 at 02:11 PM Reply With Quote
This is my Viento with a straight 6 2.8 BMW engine in it (not on the road yet though). You will need to modify the sump on a BMW engine to fit most 7's other than a GKD as it has a bulge on the side that will not clear the lower engine bay chassis rail.
MarcV
posted on 15/4/13 at 08:13 PM Reply With Quote
Can't you use the sump off a 5 series (E34 for example). These have the bulge at the front rather than the back.
The Viento seems very long, even the straight six seems somewhat lost ;-)
SteveWallace
posted on 15/4/13 at 09:23 PM Reply With Quote
Having looked at the picture again, I see what you mean - its quite a deceptive angle. The engine is as far back as I can get it and the picture below shows how close to the front it comes. That said, the Viento is a bit longer than other 7's.
As regards using a sump with the bulge at the front, I had a look at that and I concluded that there would still not be enough room. You would also probably have to move the oil pickup as well. The second picture shows the mod to the sump that I had to make. Not to difficult if you have access to someone who can weld ali.
[img] radiator hoses
radiator hoses
[/img]
[img] modified sump on engine
[/img]
ManuFromParis
posted on 15/4/13 at 10:17 PM Reply With Quote
http://www.gkdoc.com/
is the GKD Owner Club.
Not very active forum, but most of the builts have been blogged or links posted there.
Huge source of information when considering this route...
That said, if you don't go for the M3-6 cylinder, which has much more power than the standard 328 (only 193hp with huge torque though), the ST170 option or simillar 4cylinder 2L shall be considered as well, because much lighter and easier for anciellaries and much easier for fitting, I guess.
morcus
posted on 16/4/13 at 06:17 PM Reply With Quote
Thanks, I'd rather have a 4, but it's finding a 4 speed autobox that isn't computor controlled attached to one. Thanks for all the pictures and links though.
Volvorsport
posted on 16/4/13 at 07:54 PM Reply With Quote
ovlovs have aw71s the redblock without ecu and lockup torque converter aswell
whiteblocks have an aw71 with an ecu .. although its no hardship to get rid of it , it will still work as an auto ...
